Sony DV/Cineform codec conflict in project?
Posted by Rick Anvican on July 5, 2014 at 1:00 pmHi all,
I’m dealing with a project that is using (well, trying to use) footage both sourced in the Sony DV and Cineform codecs, for some reason when both DV and Cineform footage are placed on the timeline, during playback, Vegas(12 b770 x64 on Win7) hangs and Resource Monitor says that Vegas threads are in waiting status or sometimes not responding. Can someone please confirm this? The DV footage plays fine in the timeline if the Cineform footage is absent from the project. I can also use DV at the same time with Lagarith, MPEG1/2/4, etc, maybe the two don’t mix?Thanks in advance,
RickAVCRick Anvican replied 12 years, 2 months ago 3 Members · 13 Replies -
John Rofrano
July 5, 2014 at 4:28 pm[Rick Anvican] “The DV footage plays fine in the timeline if the Cineform footage is absent from the project. I can also use DV at the same time with Lagarith, MPEG1/2/4, etc, maybe the two don’t mix?”
You didn’t say how well the project plays with just CineForm footage on the timeline. Perhaps it’s an issue with the CineForm codec? There are several versions of the codec and not all of them work with Vegas Pro 12.0.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Steve Rhoden
July 5, 2014 at 4:50 pmWhats the specific problem when you have only the Cineform on the timeline?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
https://www.facebook.com/FilmexCreativeMedia -
Rick Anvican
July 6, 2014 at 8:23 amHi John, Steve,
if either DV or Cineform footage are on the timeline, they play full speed on Best(Full), cineform version is 2.0.1.319, if both formats are on the timeline, even if the events are muted, Vegas would hang during playback.RickAVC
Steve Rhoden
July 6, 2014 at 1:05 pmWell if thats the situation, no workaround is gonna make Cineform
behave any better. So converting them into another format then
dropping them in Vegas is one solution.
Or you can try download and install the free GoPro Studio Edit Software
which includes an updated Cineform Codec, and see if things behave better.
https://gopro.com/software-app/gopro-studio-edit-softwareSteve Rhoden (Cow Leader)
Rick Anvican
July 6, 2014 at 1:22 pmI guess conversion is probably the more realistic solution, but I’ll try the updated codec to see if it works. Initially I thought it was the Panasonic DV codec causing the problem but it wasn’t, anyway thanks Steve,
RickAVC
John Rofrano
July 6, 2014 at 5:47 pm[Rick Anvican] “if either DV or Cineform footage are on the timeline, they play full speed on Best(Full), cineform version is 2.0.1.319, if both formats are on the timeline, even if the events are muted, Vegas would hang during playback.”
I can have DV and CineForm AVI files on the timeline in Vegas Pro 12.0 Build 770 without any problems at all. It doesn’t matter which one I add first, the other always works. I’m using the CineForm codec that comes with NeoScene HD 5.6.2. I have no other GoPro software on my system.
~jr
Rick Anvican
July 7, 2014 at 3:11 amJohn, nice to know one version of the Cineform codec that works with DV, Neoscene HD doesn’t seem to be around anymore, do you know if there is a place to download your particular version? Thanks,
RickAVC
John Rofrano
July 7, 2014 at 12:35 pm[Rick Anvican] “do you know if there is a place to download your particular version?”
Unfortunately not and it’s a shame how CineForm was so close with Sony and now it’s so shaky. Mine is an old version that I bought just before GoPro bought them. I would contact Go Pro and ask them what version of CineForm that they currently sell is compatible with Vegas Pro 12.0 and have them help you.
You might want to try uninstalling the Panasonic DV codec. Vegas Pro doesn’t need it and there is a 50/50 chance that it’s the problem as well.
~jr
Rick Anvican
July 7, 2014 at 2:08 pmI’ve tried uninstalling the Panasonic DV codec and it seems to have no effect on the issue, I use this codec in Virtualdub for encoding, I’ll try the Cineform codec in the latest GoPro Studio and see how that goes, thanks for the tip John,
RickAVC
John Rofrano
July 8, 2014 at 10:54 amSorry none of that worked. Good luck and let us know what finally works.
~jr
