Activity › Forums › Apple Final Cut Pro Legacy › Sony Dsr-Du1
  • Posted by Maurizio Panella on August 2, 2009 at 3:36 pm
    I have some problems with this device
    I can see correctly the clips captured with PD170 with QuickTime Player
    I can see correctly the clips in the browser of the Log and Transfer window (except of the aspect ratio but this is not a problem)
    But after the logging the clip is defected
    Video is correct but audio glitches and is unusable
    Sorry for my poor english
    Please help me
    Maurizio, Italy
    FCS 6.0.6
    Maurizio Panella replied 17 years, 1 month ago 3 Members · 7 Replies
  • 7 Replies
  • Steve Eisen
    August 2, 2009 at 3:55 pm
    Make sure the device is setup using the AV/C Protocol and not the SBP2. Use log and capture. The device will act like a VCR in AV/C mode. The native files from this device have never been supported by any version of FCP (SBP2).
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Maurizio Panella
    August 2, 2009 at 11:03 pm
    I have the manual in pdf and I change the setting to follow your advice
    Now I cant see the DSR-DU1 in my desktop
    I think it’s impossible to use this device
    Anyway, thank you
  • Tom Wolsky
    August 2, 2009 at 11:08 pm
    Does the DU1 mount on the desktop? Log and transfer is not used for DV material. If you have DV material recorded on the disk you should be able to simply drag it onto your computer.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Steve Eisen
    August 3, 2009 at 1:31 am
    I have not used this unit but I did do research on it when it first came out. You should be able to connect the unit via firewire to your computer. Open up log and capture and the device should show up as it was a DV Deck.
    Steve Eisen
    Board of Directors
  • Tom Wolsky
    August 3, 2009 at 1:51 am
    I could well be wrong but I’m pretty sure log and capture is only for tape based media.
    All the best,
    Tom
  • Steve Eisen
    August 3, 2009 at 2:50 am
    Here is a review from a long time ago.
    https://digitalcontentproducer.com/mag/video_sony_dsrdu/
    As I said, I have never used the unit.
    Steve Eisen
    Board of Directors
  • Maurizio Panella
    August 4, 2009 at 8:36 am
    Steve advice was correct
    Is not possible to connect the DSR-DU1 with the SBP2 protocol in the Mac
    It’s an official Sony document
    So I have to setting the hd like a vcr and is not important if I cant see the hd icon on desktop
    There is no problem to capture via iMovie, all is correct
    If I try to import directly in Final Cut pro I have this message
    Error: Final Cut Pro was unable to read the movie file just captured
    When I import in Final Cut Pro the files captured via iMovie I have no problem
    Only the audio need to render
    So maybe this is a possible solution
    Capture in iMovie and then import the same files in Final Cut Pro
    I will try to change some audio settings in my PD170 sd camera to see if something change
    Thanks to all and sorry for my poor english
    Maurizio, Italy
