Activity Forums Blackmagic Design Sony DSC1024HD scan convertor into Intensity Pro?
  • Sony DSC1024HD scan convertor into Intensity Pro?
    Posted by Roger Bolton on January 13, 2010 at 10:31 am
    Hi, I am trying to get the output from a Sony DSC 1024HD scan convertor into an intensity Pro as 1080i HD under Windows XP SP2.
    I am just trying to test the input with the Amcap test program in Windows so far. Its working fine in PAL mode already, but when I set the DSC1024 to 1080i output and then set the BlackMagic to 10830Psf I’m not seeing any input come up.
    The DSC is set to YBR mode and to Composite Sync so the sync should be contained in the YBR connection. Anyone got this combination of devices to work correctly?
    CoreMelt V2 plugins
    Roger Bolton replied 16 years, 8 months ago 1 Member · 1 Reply
  • Roger Bolton
    January 13, 2010 at 1:34 pm
    Updated the BM software to 3.4 and tried using Media Express as well, same symptoms, works fine at PAL but not at 1080i.
    I also have an edirol V440 HD mixer here, and that works fine going into the BM at 1080i so I know that the cabling is correct.
    does the BM Intensity support 1080i YBR sync on green at 59.94?
    CoreMelt V2 plugins
