Activity Forums Apple Final Cut Pro Legacy Sony Deck not responding
  • Sony Deck not responding
    Posted by Kevin Matluk on September 30, 2009 at 2:20 pm
    Trying to capture footage from my Sony M35u deck and it is not responding to anything. I pressed play on the deck and the tape started, everything working fine, and all of the sudden when I go to stop it, none of the buttons on the deck work, stop, pause, power, eject, nothing works and the tape is still playing, How do I fix this? Any ideas?
    Kevin Matluk replied 16 years, 11 months ago 2 Members · 2 Replies
  • Doug Beal
    September 30, 2009 at 2:34 pm
    Unplug the deck from power
    power back up and see if you have a hardware switch named “key inhibit” make sure it’s off
    if it’s not a hardware switch it may be a menu item.
    I don’t know this deck but thats the behavior on the pro decks when key inhibit is on.
    It may also be menu settings if it thinks it’s in remote.
    sometimes a reboot helps. ie power down power up
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Kevin Matluk
    September 30, 2009 at 2:52 pm
    Thanks for your response Doug, The Key Inhibit switch was on, switched it off and everything is Good! Thanks a lot, I never even knew what that switch was used for, Thanks again Doug
