Activity Forums Avid Media Composer sony dbeta lifespan?
  • sony dbeta lifespan?
    Posted by Mike Miller on February 17, 2009 at 2:40 pm
    Hey all…not sure what forum this should be posted in, but, figured many of you may use a DVW-A500 dbeta in your work. what I’m trying to determine is where is my deck in it’s lifespan based on the number of hours…it need a new circuit board which could run the repair in the 3k to 6k range and i am weighing my options…
    so, how do these numbers compare to yours!?
    New>>>>>>>>>>>>>>>>>mid- life>>>>>>>>>>>>>>>>>dead?
    Sony-DVW-A500
    H01 OPE HOURS = 26,315
    H02 DRUM HOURS = 1,823
    H03 THREAD COUNT = 6,995
    thanks!
    mike
    Grinner Hester replied 17 years, 7 months ago 2 Members · 1 Reply
  • Grinner Hester
    February 19, 2009 at 12:25 am
    If you use it often, go ahead and do the swap. If not, see what you can scap it for then just rent as ya need.
    I managed to avoid ever buying one… my main client being a betaSP house. I rented when I needed to but I don’t see ever having to do it again at this point.
