Activity Forums Apple Final Cut Pro Legacy Sony Cyber-shot DSC-RX10 workflow
  • Sony Cyber-shot DSC-RX10 workflow
    Posted by Robert Withers on September 22, 2014 at 1:46 am
    I have no clear idea where to post this, so apologies if you see in in a few groups.
    I’m trying out a Sony Cyber-shot DSC-RX10 , which has a great compact form factor, Zeiss 25-200 lens, good controllable audio levels recording with the Rode VideoMic pro, but I’m challenged trying to figure out a work flow for the files.
    I can work in Premiere CC or FCP7 on a Mac.
    The camera gives various recording options, including to record in 60p AVCHD or MP4. (There’s a firmware update that will enable 30p.)
    I selected 60p and shot a couple of hours.
    Used Sony’s “PlayMemories Home” software to transfer to a hard drive.
    The software transferred duplicate copies of each clip, one a 59.95 fps in .mst wrapper and one at 29.97 in .mp4 wrapper.
    In premiere CC, for example, both versions of each clip import into a project.
    Interesting questions:
    1. Why would the camera record duplicate clips in two formats when I selected one? (Actually I think “PlayMemories Home” is doing the duplication.)
    2. When I put the card in my Macbook Pro card slot I can transfer the folder directly, much faster, skipping the “PlayMemories Home” process. The MP4 duplicates of the AVCHD clips don’t appear.
    3. No problems importing into Premiere CC. Will there be issues and are there tricks to import into FCP7?
    Thanks for your thoughts,
    Robert
    Robert Withers
    Independent/personal/avant-garde cinema, New York City
    Robert Withers replied 12 years ago 2 Members · 2 Replies
  • Mark Suszko
    September 22, 2014 at 1:33 pm
    Or you could buy FCPX, and use it just as a transcoding application… then eventually, you might get around to trying to edit with it… it really isn’t too bad. It too can handle the files natively from your Sony, or, it can transcode them in the background, while you work. And for now at least, it doesn’t lock you into monthly payments.
    As to why the Sony generates two sets of files, it probably does that to make it easier to share the video to Sony gear, for those more casual consumer users.
  • Robert Withers
    September 22, 2014 at 6:58 pm
    Thanks everybody. Importing directly from the card to a Mac drive worked fine, much faster than the Sony software, and PP handles the footage easily. I shot this for a friend who works with FCP7, so more will be revealed. There is a firmware update (new codec XAVC-S), which also enables 30p and 120p. Have heard about difficulties importing it.
    Robert Withers
