Activity Forums Sony Cameras Sony Clip Browser
  • Sony Clip Browser
    Posted by Michael Jones on July 24, 2012 at 6:10 pm
    Does anyone know a quick way to just look at a BPAV folder and see how many clips are in that directory through the clip browser? Just want to be able to confirm that I have successfully duplicated that folder to a second backup.
    -mj
    Michael Jones replied 14 years, 1 month ago 2 Members · 6 Replies
  • Ian Cook
    July 24, 2012 at 6:22 pm
    In one of the Explorer windows on the left, navigate to the folder containing the archive/copy. Once Browser sees the folder it should place an EX overlay on it (identifying it as a folder with EX clips) and display the contents of the archive just as it would from an SxS card.
  • Michael Jones
    July 24, 2012 at 8:07 pm
    That sounds like a PC feature… I’m Mac OS. I moused around and did not see anything pop up. I just want to see that I have 43 clips in that folder at a glance.
  • Ian Cook
    July 24, 2012 at 8:10 pm
    No, it’s the same for both versions on either OS. It’s really the best way to QC a copy as you will see actual thumbnails and video instead of just a list of files. If you want to see the copy at the filesystem level go to [Folder name]/BPAV/CLPR. Each folder inside CLPR represents a clip (the folders inside CLPR contain the .mp4-wrapped video file and related sidecar files)
  • Michael Jones
    July 24, 2012 at 8:19 pm
    OK, maybe I’m missing something. When I have a ton of clips and sometimes I like to combine cards into one BPAV through Clip Browser. That way all the clips are in one folder. Then when making a backup I want to make sure ALL the number of clips match. The only way I see the number is when I make a “copy all” action. Alternatively, I want to see quickly within CB, see how many actual clips are there. Just a simple number of clips.
  • Ian Cook
    July 24, 2012 at 8:29 pm
    Go to the folder, select all and look at the bottom of the thumbnail/details area. It will always show how many clips are currently selected so when you do a CTRL+A you’ll see the total # of files. See bottom of image below..
  • Michael Jones
    July 24, 2012 at 8:38 pm
    That’s It! Thank you sir! I knew it had to be somewhere.
