Activity Forums Corporate Video Sony Cameras
  • Sony Cameras
    Posted by Corbin Gross on August 24, 2007 at 6:21 pm
    Hello, Everybody
    I know you hate the question- ‘Which camera is better?’ And I know it’s just a tool and the artist is what really matters.
    That said, I’m buying a new camera for our internal training videos and web adds and stuff. Everything is displayed online in standard progessive scan files. I’m looking at the Sony’s HDR-FX1, FX7, HVR-Z1U, and V1U. All I can really find is press releases. I can’t find where to compare the products on CNET and B&H.
    Assuming all the studio and minimal location pictures will be equally nice looking, can you let me know if any of the features, like XLR’s or handily placed LCD’s make one of these shine. I am aware of basic ways to wire XLR to mini and alternate viewing options but there must be a reason some are more expensive than others.
    Marco Solorio replied 18 years, 11 months ago 5 Members · 8 Replies
  • 8 Replies
  • Craig Seeman
    August 26, 2007 at 2:04 pm
    You mention “studio” and by use of “minimal” location that studio will be predominant. Do you know that the V1’s HDMI output can allow you to avoid the HDV (mpeg2) compression of the other cameras? That would give the V1 a BIG advantage IMHO. It can allow for much better graphics compositing/green/blue screen for example.
    I’d also only consider a camera with XLR ins unless you plain on recording to an external sound device. Once you start adding devices (such as the Beachtek) you’re negating the already marginal cost advantage of the non XLR cameras which also have fewer features in other regards.
    The Z1 gives you the advantage of shooting both PAL and NTSC if that’s important to you. It’s inerlace only though so if you’re target is predominately progressive, you’ll be deinterlacing everything. The Z1 handles low light a bit “better” (better is subjective since it involved such things as detail, noise, color as well as light sensitivity) than the V1 but that’s only critical if you shoot low light.
    All you can find are press releases? Are you “Googling?” There are a PLETHORA of reviews on all the aforementioned cameras . . . probably an overwhelming number. The quality of the rewiew itself may vary but given the popularity of the cameras they were heavily reviewed camaras.
  • Marco Solorio
    August 27, 2007 at 11:22 pm
    From what you’re describing, the only Sony camera I’d suggest in your line up would be the V1U because it’s native 24p. However, have you looked into Panasonic and JVC solutions? I wouldn’t go the Canon route since they do not offer a native 24p camera.
    Marco Solorio | CreativeCow Host | OneRiver Media | Codec Resource Site | Cinesoft | Media Batch
  • Accountclosed
    September 6, 2007 at 4:36 pm
    I wouldn’t buy the Sony V1U for it’s jacks, given that the audio frequency response of it is “dumbed down”. See https://aamserver.dnsalias.com/basspig/HVR-V1U_PCM_Audio(DV).htm for the actual response tests.
    In other respects, yes, the V1U is quite good–as long as you plan to use studio lighting and have the levels at at least 20KLux. The stronger the lighting, the crisper the images. V1U shoots great outdoor footage on a sunny day, but indoor results vary. Normal room lighting is not enough, as the picture gets soft and noise increases to intolerable levels for a professional production. But this is somewhat true of all HDV cameras.
    Take care,
    Mark & Mary Ann Weiss
    https://www.basspig.com The Bass Pig’s Lair – 15,000 Watts of Driving Stereo!
    https://www.mwcomms.com
    https://www.adventuresinanimemusic.com
  • Craig Seeman
    September 6, 2007 at 4:56 pm
    I’d consider having a camera with XLR jacks over minis important even with mediocre audio. There’s just far to many issues with mini jacks and such cameras often make it difficult to split the audio, take a line feed (which you can do on Sony cameras with XLRs), disable AGC on one (or both) channels.
    One might have a close look at the Sony XDCAM EX but we’ll have to see the early reviews after IBC. It might be a different price point.
  • Ryan Santos
    October 25, 2007 at 12:38 pm
    You mean Canon’s 24F is not really progressive?
  • Marco Solorio
    October 25, 2007 at 5:23 pm
    This is correct. Canon’s CCDs are interlaced, so it performs interpolated deinterlacing on-the-fly. It gives you a 24p “look” but it’s not native 24p like a progressive CCD camera will give you.
  • Ryan Santos
    October 25, 2007 at 10:28 pm
    … which means 24F is not 24P. The Canon XL2’s brochure says it’s 24P (not 24F like the XL H1). Does that mean the XL2 has real progressive CCDs unlike it’s big brother, the XL H1?
  • Marco Solorio
    October 25, 2007 at 10:54 pm
    Ryan, I think I stand corrected. It does look like in fact the XL2 uses true progressive CCDs. I have heard it looks soft in 24p mode so I’m not sure whay that would be.
