Activity Forums Broadcasting Sony BVS-3100 Beginner Question – Button Flashing
  • Sony BVS-3100 Beginner Question – Button Flashing
    Posted by Keith Parkansky on April 13, 2012 at 4:36 am
    I have a BVS-3100 switcher with several inputs, one of them being a color bar generator. (Note that this switcher appears to be the same as the Grass Valley 110 switcher.)
    When I select the color bar generator on the program bus the button flashes but the color bars appear on the program monitor just fine. If I select ‘color background’ on the program bus that button doesn’t flash (and the color background appears on the program monitor just fine).
    If I select the color bars on the preview bus the button doesn’t flash and the color bars appear on the preview monitor just fine.
    I have a PDF of the manual but nothing in it says what is indicated by a flashing button.
    Does anyone know what is indicated by a flashing button ?
    Thanks in advance.
    Keith Parkansky replied 14 years, 5 months ago 2 Members · 2 Replies
  • Tom Matthies
    April 13, 2012 at 7:12 pm
    On many of Sony’s pieces of equipment, a flashing light means either a missing signal or a non-synchronous signal. Since the switcher is passing the bars, I’d guess it might be the latter. Check your manual for the section on reference inputs or gen-locking to see if it’s mentioned. Are the bars and the switcher locked to a common reference?
    E=MC2+/-2db
  • Keith Parkansky
    April 14, 2012 at 5:21 am
    I don’t recall if the color bar generator had any sort of gen lock connection. it’s a Tektronix. I’ll have to check. I’m also finding that some of the connectors on my home-made BNC cables have bad crimps on the center pin so if I do have it connected it may not be connected well. Thanks!
