Activity Forums AJA Video Systems Sony BVM-1910?
  • Sony BVM-1910?
    Posted by Bill Marcellus on July 1, 2006 at 10:43 pm
    I have read many times that the Sony PVM-20L5/1 is the most desirable monitor for HD color correction…and that they are no longer being manufactured.
    My question is this- would a Sony BVM-1910 serve as a decent monitor for CC work? The specs claim 900 lines of rez (vs. 800 for PVM-20L5). I would be sending the signal via component outs on a Kona 2.
    Any input or advice is appreciated.
    Bill
    Walter Biscardi replied 20 years, 2 months ago 3 Members · 4 Replies
  • Walter Biscardi
    July 1, 2006 at 11:03 pm
    [Bill Marcellus] “My question is this- would a Sony BVM-1910 serve as a decent monitor for CC work?”
    According to the specs I just read, it’s an SD monitor only. If you’re working in HD, you need an HD monitor. You can get the 14″ PVML5/1. We have that in our second suite and if you need something bigger for your client, you can add a secondary monitor for them.
    The BVM series is actually a higher quality line than the PVM series. I’ve only found the 1910 as a used monitor.
    Walter Biscardi, Jr.
  • Bob Zelin
    July 1, 2006 at 11:12 pm
    no
    bob zelin (listen to Walter)
  • Bill Marcellus
    July 2, 2006 at 1:22 am
    Thanks guys- I was hoping that you would be the ones to answer my question. We just happened to have a BVM-1910 sitting around, etc.
    Thanks again.
    Bill
  • Walter Biscardi
    July 2, 2006 at 3:02 am
    [Bill Marcellus] “We just happened to have a BVM-1910 sitting around, etc.”
    they’re selling for about $2,500 on up at the Broadcast Store used, so maybe you might want to sell it and use that towards a newer HD monitor.
