Activity Forums VEGAS Pro Sony AVC Codec?
  • Sony AVC Codec?
    Posted by Mark Prebonich on October 23, 2011 at 5:29 am
    After the switch to Vegas Pro 11, the Sony AVC render option is no longer there. I have tried to uninstall and reinstall and it appears that there are two “Sony” render types that are no longer present compared with Pro 10. Any thoughts as to what to do to fix this? Thanks.
    -Mark
    Thomas Roell replied 14 years, 10 months ago 4 Members · 4 Replies
  • Mark Prebonich
    October 23, 2011 at 5:38 am
    If I have Vegas Pro 10 installed along with 11, then all is well. If I uninstall 10 then Sony AVC render option disappears. If I then uninstall 11 and reinstall 11, it does not come back.
    -Mark
  • Mike Kujbida
    October 23, 2011 at 12:21 pm
    This problem has been reported by several users on various Vegas forums so it’s obviously a bug that will hopefully be addressed very soon.
  • Dave Haynie
    October 23, 2011 at 5:16 pm
    I’ve seen the Sony AVC CODEC vanish once or twice, without installing or re-installing anything. It just didn’t show up. There’s some random bug in the new file dialog.
    I found that re-starting Vegas solved my problem. And honestly, I still have Vegas 9 installed, and find no possible reason to un-install Vegas 10 at this point in time. Not that it should matter…
    -Dave
  • Thomas Roell
    October 24, 2011 at 2:16 am
    You have “Match Project settings” checked. Uncheck this, and there is the Sony SVC coded. Then you can create your custom template …
    Why not use the MainConcept AVC codec ?
