Activity › Forums › Apple Final Cut Pro Legacy › Sony A7S and FCP 7 Workflow
Posted by Jamie Lee on July 23, 2014 at 7:58 pmHas anyone worked with media from the Sony A7S camera. Looking for some tips regarding post workflow and getting the media into FCP 7.
Import XML isn’t working, it asks for a navigational file and gives us an error.
I have h264/mpeg4s of the footage which I’d rather not use since its a compressed codec that doesn’t always get along with fcp.
Any and all advice is welcome and appreciated.
Shane Ross replied 8 years, 8 months ago 21 Members · 34 Replies -
Shane Ross
July 23, 2014 at 10:03 pmConvert the footage to ProRes 422. You can do this with Compressor or MPEG STREAMCLIP…or BulletProof from Red Giant.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Jamie Lee
July 24, 2014 at 3:01 pmThanks Shane!
I can’t get the XML’s to open in compressor or mpeg streamclip. Going to give Bulletproof a try.
Shane Ross
July 24, 2014 at 4:51 pmXML isn’t media…that’s just metadata. It’s the MP4 or H.264 Quicktime files that you need to convert.
Shane
Little Frog Post
Neil Sadwelkar
July 25, 2014 at 4:19 amAnd if you need to re link to original media after edit, avoid using MPEG Streamclip. It strips out all original timecode and reel name.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India -
Chris King
August 28, 2014 at 1:27 amWhen you wan to import the XAVC S videos from Sony A7S to Final Cut Pro 7 for editing the movies, you may find the high quality XAVC S files are not recognized by FCP.
The basic reason why we can’t work Sony A7S XVAC S with Final Cut Pro is that XAVC S codec is a new one, and is not widely supported. To make the XAVC S compatible with FCP, the easy workaround is to convert XAVC S to ProRes MOV, which ensures best results when using in Final Cut Pro 7.
Mark Hayes
August 31, 2014 at 8:17 pmShane,
Bullet Proof won’t export ProRes clips with footage from a7s. Does fine with clip from FS700?
I can see the a7s clip(s) in the BulletP window. I select them and EXPORT and get “This Export Had Errors” message.
Mark Hayes
Shane Ross
September 1, 2014 at 5:46 pmBulletproof won’t do this. EditReady from Divergentmedia.com will. Or you can use an editing app that works with it natively, like Adobe Premiere Pro.
Shane
Little Frog Post
Mark Hayes
September 9, 2014 at 1:30 amShane,
EditReady worked great and it’s fast.
You can work natively with the XAVC S codec in FCP X without transcoding, but not in FCP 7 as far as I know. Needed to hand the footage off to someone using FCP 7.
Thanks for the help.
Mark Hayes
Giuseppe Mangione
September 13, 2014 at 1:16 pmWe have a documentary to shoot this October in Italy and I have a similar problem.
The cameraman is coming from LA with the Sony A7s… It seems the perfect camera for the low light we will have in the cellars! This Doc is about wine and the people who make it.
Our editor is based in Chicago, and she will be editing with FCP7. So Before I sent her the drive I want to convert all the XAVC clips to ProRes.
Here in Italy, I have the updated FCPX. What do you think to use FCPX to transcode (selecting create optimized media when I import)? It seems pretty fast and reliable!
Considering the XAVC-S codec is at 50Mbps, which ProRes setting Should I use? ProRes 422, ProRes 422 HQ, or ProRes 422 LT?
Giuseppe
