Activity Forums Live Events & Streaming Sony 4K Projector
  • Sony 4K Projector
    Posted by Thomas Leong on August 12, 2010 at 3:31 pm
    Does anyone have experience with this behemoth?
    https://pro.sony.com/bbsc/ssr/product-SRXT420/
    My questions are –
    1. What graphics card would be able to output to that 4K native resolution? Even the ATI Eyefinitiy line seems to output only 2560×1600 max per output. Any ideas?
    2. What source material would be suitable? Red 4K? I have no experience with that. Haven’t even seen one in my life, therefore, is The Red 4K’s output 4096×2160? Would it be the only source material suitable apart from original gfx material from a compositing software like After Effects or Digital Fusion?
    PS: Might have a chance to look/check the Sony out in Hong Kong next week (hehehe) so wanna be prepared somewhat.
    Thanks in advance,
    Thomas Leong
    Scott Buford replied 16 years ago 3 Members · 5 Replies
  • Scott Buford
    August 12, 2010 at 7:23 pm
    From what I understand the only way to playback native 4k material is by syncing 4 playback devices
    Doremi recently came out with a standalone 4k playback device:
    The DSV-J2 with an optional input called MB-4k
    https://www.doremilabs.com/dsv.html
    It has 4 DVI and 4 HD-SDI outputs that you use simultaneously.
    Hope this helps, and keep us posted.
  • Thomas Leong
    August 13, 2010 at 12:09 am
    Thanks for the info Scott.
    My associates’ client in Hong Kong has ordered a Quad Media Engine from AvStumpfl (purpose-built PC with 4 synced outputs from their Wings Platinum 4 software). Hope this will suffice to feed 4K inputs into the Sony like the Doremi DSV-J2. Material is a worry at this point.
    Shall keep this forum posted.
  • Walter Soyka
    August 13, 2010 at 1:24 am
    The great thing about standards is that there are so many to choose from! “4K” can refer to any of a variety of different resolutions, depending on aspect ratio.
    [Scott Buford] “From what I understand the only way to playback native 4k material is by syncing 4 playback devices. Doremi recently came out with a standalone 4k playback device: The DSV-J2 with an optional input called MB-4k”
    4K playback exists, but it’s entirely limited to the digital cinema market. DoReMi has had a 4K playback device for some time — the DCP-2K4 Digital Cinema Server. Sony has the LMT-100 media server. Both play Digital Cinema Packages (DCP), which require an expensive DCP authoring package to create and encode.
    [Thomas Leong] “What source material would be suitable? Red 4K? I have no experience with that. Haven’t even seen one in my life, therefore, is The Red 4K’s output 4096×2160? Would it be the only source material suitable apart from original gfx material from a compositing software like After Effects or Digital Fusion?”
    Red’s 4K is 4096×2304. As you may have read, its REDCODE workflow is a bit different than other video cameras.
    Film is still around, too — you could shoot film and scan it at 4K.
    I’m looking forward to hearing more about your findings!
    Walter Soyka
  • Thomas Leong
    August 13, 2010 at 1:41 pm
    Just saw a couple of REDs in a 3-D config close up today in Singapore!! An over-under mirror setup.
    But bad news is that the Quad Media Engine from Austria won’t arrive in Hong Kong till about 2 weeks’ time, so can’t get to test the Sony T420 next week while I’m there. Will have to be the next trip when I have to be there to receive the Quad Media Engine and check it before delivery to client. Hope my associates can still arrange for the Sony then.
  • Scott Buford
    August 18, 2010 at 8:02 pm
    Walter is absolutely correct. I should have been more clear. I was referring to non digital cinema options because I assumed that was not appropriate for Thomas’s workflow.
    Thank you for the clarification Walter!
