Activity Forums VEGAS Pro sony 10C fx problem
  • sony 10C fx problem
    Posted by Bill Jackson on April 7, 2011 at 9:56 pm
    When I open the FX window and put the FX on the timeline. Some of them will not work. Glint and several others. Also I have this problem with Pro-Titler.
    The text in the fX window is very small and the sliders will not work. Also at the top of the screen where you click on the File Edit’s, etc. they double and the text is very small. I have to close and reopen the program to get it back to normal.
    I am running windows I7, 64 bit, 24meg memory 4 HDD.
    I have tried eveything I know, nothing has solved my problem.
    Your help would be greatly appreciated
    Bill
    John Rofrano replied 15 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
  • Steve Rhoden
    April 8, 2011 at 2:38 am
    Which version of Vegas are you using, 32bit or 64bit?
    You already have a competent system so i am wondering if
    something you have installed is causing this issue.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
  • Nigel O’neill
    April 8, 2011 at 3:51 am
    Can’t see I have experienced this particular problem on either the 32 bit or 64 bit SVP10. Have you tried defaulting Vegas?
    Hold down CTRL-SHIFT whilst starting Vegas.
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Bill Jackson
    April 8, 2011 at 4:25 am
    Thanks for your help. It is a 64bit system. It was built by adk computers. It is brand new.
    Bill
    Bill
  • Bill Jackson
    April 8, 2011 at 4:29 am
    I have tried defaulting the system. But I held down the ctrl shift alt keys.
    Bill
    Bill
  • John Rofrano
    April 8, 2011 at 12:41 pm
    Have you changed your Windows font size from the default? Sometimes changing the DPI will make applications behave strange.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Bill Jackson
    April 10, 2011 at 12:10 am
    Hi John,
    Setting the font size to default solved the problem. Thank you so much for th answer to my problem.
    Best to you
    Bill Jackson
    Bill
  • John Rofrano
    April 10, 2011 at 3:41 pm
    Yea, it is never a good idea to change the Windows font size. It is implemented so poorly by Microsoft that it should just be avoided at all costs. Glad that fix it for you.
    ~jr
