Activity › Forums › VEGAS Pro › Sony 10 premium hangs up or will not work
  • Sony 10 premium hangs up or will not work
    Posted by Rod Simonian on May 20, 2011 at 11:43 pm
    HI
    when I stat the program up and add my project to the time line the preview is red.
    I just doubled my system memory to 6GB
    I can fix this problem by starting up
    Fire fox Now back to V10 and the preview is not there WTF is this a driver problem or something in fire fox that is now running that was not running before?
    The other problem happens when I cancel something the program just hand up and will not close which causes me to reboot.
    Thanks for any help
    Rod Simonian replied 15 years, 4 months ago 3 Members · 9 Replies
  • 9 Replies
  • Rod Simonian
    May 21, 2011 at 3:49 am
    should read the preview is there.
  • Stephen Mann
    May 22, 2011 at 2:50 am
    Update your video drivers.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Rod Simonian
    May 22, 2011 at 4:45 am
    Hi Thanks
    I am downloading the driver now. for nvidia Geforce 450
    It is the same one that now running the hardware.
    I will re do it and let you know what happens
    Thanks Again
    Rod
  • Rod Simonian
    May 22, 2011 at 5:33 am
    NO still the same problem . I will check to see if the video card that is on the mother board is turned off
  • Nigel O’neill
    May 22, 2011 at 12:26 pm
    Rod
    What version of Vegas are you using? It could be a codec compatibility issue.
    What video file format are you trying to load? Vegas generally does not support DIVX and is a bit touchy with certain versions of Quicktime mp4’s.
    One way to tell is highlight the file in Vegas’ Explorer window. If Vages recognises the audio and video stream, it displays information about the file.
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Rod Simonian
    May 22, 2011 at 4:15 pm
    HI
    The clips that I used started with MOV extension. I then renamed them to mp4 I did this because MOV in Vegas 9 would not have sound
    Here is the info on the clips
    General
    Folder: C:\Documents\SAW ITEMS\2152 kit
    Type: QuickTime
    Size: 182.38 MB (186,758,358 bytes)
    Created: Tuesday, May 10, 2011, 5:39:56 PM
    Modified: Sunday, May 08, 2011, 4:50:36 PM
    Accessed: Tuesday, May 10, 2011, 5:39:56 PM
    Attributes: Archive
    Streams
    Video: 00:01:43.704, 29.970 fps progressive, 1920x1080x24, H.264
    Audio: 00:01:43.659, 48,000 Hz, 16 Bit, Stereo, AAC
    ACID information
    ACID chunk: no
    Stretch chunk: no
    Stretch list: no
    Stretch info2: no
    Beat markers: no
    Detected beats: no
    Other metadata
    Regions/markers: no
    Command markers: no
    Media manager
    Media tags: no
    Plug-In
    Folder: C:\Program Files (x86)\Sony\Vegas Movie Studio HD Platinum 10.0\FileIO Plug-Ins\qt7plug
    Format: QuickTime 7
    Version: Version 1.0 (Build 7330)
    Company: Sony Creative Software Inc.
    Let me know and thanks
    Rod
  • Rod Simonian
    May 22, 2011 at 6:19 pm
    When trying to render I get the message that I do not have windows media codec running win 7 64 bits. Which one do I need
    thanks
    rod
  • Nigel O’neill
    May 23, 2011 at 3:36 am
    Sony Vegas will not encode QuickTime h.264 files.
    You use the Sony AVC “render as” preset and select the highest resolution with the = in front (this means that the preset matches your project parameters). Then use Apple Quick Time Pro (it’s not free, but reasonably cheap) to make the QT file.
    You might also want to search this forum for Quicktime and read the threads.
    https://forums.creativecow.net/thread/24/927210#927217
  • Rod Simonian
    May 23, 2011 at 3:44 am
    This program a real piece of junk
    I did find a work around. I used Windows movie maker to edit and make a movie I did not see how to add a narration. So I took the wmv file and loaded it into Vegas 10 and added the narration. It all worked like it should no red screen did not have it hang and I did render an HD movie with out a memory problem.
    It only took me 35 hours to figure this out. Now I will load it to youtube and see how it looks
    Thanks for all the help . I think I would still be having problem trying to make it work. It took this to figure out the work around.
    Maybe some one has the knowledge to use this program properly
    rod
