Activity Forums Panasonic Cameras Sometimes it works sometimes it doesn’t
  • Sometimes it works sometimes it doesn’t
    Posted by Itamar Kool on December 14, 2006 at 9:50 am
    I have a Panasonic HVX 200 combined with an FS 100 Firestore. The problem is that the connection for starting to record often doesn’t work properly. It says that there is no cennection. I turn off the camera and then it works again. What is the problem??
    Kool En De Anderen
    dual 1.8 gig G5/Mac OS 10.4.8/Kona 2/Hugh 800 G diskarray, fibrechannel/FCP 5.1.2/AE 7 Pro
    http://www.koolendeanderen.nl
    Itamar Kool replied 19 years, 8 months ago 2 Members · 2 Replies
  • D. scott Dobbie
    December 15, 2006 at 5:32 am
    I don’t use the Firestore, primarily because I’ve seen too many posts of problems. But I’ve seen your question come up here before. You might want to do a search over the past 6 weeks of posts to see if there was any resolution. Might also be good to search on Firestore in general, so you can anticipate any other issues.
  • Itamar Kool
    December 16, 2006 at 12:25 pm
    Yes. It was trange; I had to do the same thing again I had done about a week ago: change a setting in the camera
    Kool En De Anderen
