Activity Forums Adobe After Effects Sometimes in AE6.5 I can’t drag keyframes around
  • Sometimes in AE6.5 I can’t drag keyframes around
    Posted by Steve Bailey on December 10, 2005 at 3:48 pm
    Doing a photo montage and my typical MO is to go to the center of the layer (after the photo fades up and before it fades down) and set my position and scaling keyframes. Once I have it the way I want, I drag those two keyframes to the start of the layer (before the picture had faded up) and then I set another set of keyframes where I want it to end and then drag those keyframes to the end of the layer (after it’s faded down).
    Sometimes, on some layers, when I create the keyframes, I can’t drag the keyframes around and I’m forced to go to the start of the layer, set the key points and then go to the end of the layer and set the keypoints. This is a pain in the butt because I have to delete the opacity keyframes to see what I’m doing and then set them back.
    Any idea why some layers won’t let me drag keyframes around?
    Steve
    Steve Bailey replied 20 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
