Activity Forums Blackmagic Design Sometime Multibridge Extreme can’t capture
  • Sometime Multibridge Extreme can’t capture
    Posted by Lilei on September 15, 2006 at 9:07 am
    I have a question about Decklink Multibridge Extreme PCIe.My host is G5dual 2.3GHZ/2G/MAC OS 10.4.6 .When the host run sometime.The Multibridge Extreme can’t capture.And no input and output in my host.I must shut down the power.Then I first make the Multibridge Extreme run sometime,and power on G5.So the Multibridge Extreme can work properly.It happens several times .
    This is my question, please help me.
    Thanks !
    lilei
    Kristian Lam replied 20 years ago 4 Members · 3 Replies
  • Luke Maslen
    September 18, 2006 at 3:09 am
    In order for the Multibridge Extreme to work with your G5, you must provide power to the Multibridge Extreme before you switch on your G5.
    If you switch on your G5 first and then power on your Multibridge Extreme, it will not work.
    Do you always switch on the Multibridge Extreme before you switch on your G5?
    Regards,
    Luke Maslen
    Blackmagic Design
  • Miceler
    September 21, 2006 at 1:44 am
    yes,i know how to use it.I always power on the G5 before power on the multibridge,bur it also have that question,so sometime i don’t use it normally.
    hello!everyone!
  • Kristian Lam
    September 21, 2006 at 7:49 am
    [miceler] “always power on the G5 before power on the multibridge”
    Should be the other way around! Power on the Multibridge Extreme before powering the Mac.
    regards
    Kristian Lam
    Blackmagic Design
