Activity Forums VEGAS Pro somethings wrong when i use pan/crop
  • Joe Mantaratz
    November 22, 2008 at 4:24 pm
    Could you better define what you mean by black background? If you are using PAN/CROP and want to maintain the aspect ratio (it fills the screen) then make sure you have that button selected. If you are unsure as to which one that is just pass you mouse over the button selection and it will tell you which one is which. If this is not what you are having problems with please ask again.
    John
  • Mike Kujbida
    November 22, 2008 at 4:47 pm
    If this is a still image, open Pan/Crop, right-click and select “Match Output Aspect”.
