Activity Forums VEGAS Pro Something wrong in render
  • Something wrong in render
    Posted by Márcio Nascimento on December 10, 2010 at 3:22 am
    Hi all!
    I’m having problems to render MPEG files for DVD using CBR 8.000.000
    The result is some “pause-drops” in the rendered video, something like frames being duplicated (longer then the others).
    When render in VBR: 9.500.000 max / 8.000.000 avg / 7.900.000 min it’s OK, but quality decrease and the render time is 2 times the CBR.
    My clips are 1440×1080 / 60i / Upper field first / 1.333 asp.ratio with Canon HV30.
    I need to create common DVD 720×420 29,97fps.
    In CBR mode, using field order Upper or Lower makes the bad drop effect. When I change each clip in timeline to “None (Progressive)” the problem desapears but it’s blurry the image.
    Any solution? Must I continue rendering in VBR mode?
    Márcio Nascimento
    – Editor, cinegrafista e fotógrafo –
    Nigel O’neill replied 15 years, 9 months ago 3 Members · 5 Replies
  • Mike Kujbida
    December 10, 2010 at 2:29 pm
    How long is your video?
    What are your project properties set to?
    Was the source footage shot in 24p mode?
    “The result is some “pause-drops” in the rendered video…”
    Are you seeing this on a finished DVD?
  • Nigel O’neill
    December 10, 2010 at 3:14 pm
    I am experiencing similar issues. Rendered a DVD (total length less than 60 mins) of edited HDV 1080/50i PAL to DVDA template using a CBR of 8,000,000 and observed several pauses whilst previewing the video with the customer. I suggested their el cheapo DVD player was to blame and they accepted that excuse (for now).
    My quality slider and video output settings are both set to 31/best in the render template. Might try reducing it to good.
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Mike Kujbida
    December 10, 2010 at 4:07 pm
    [Nigel O'Neill] “…to DVDA template…”
    Which template?
    Did you any customizing to the template?
    What were your project settings?
  • Márcio Nascimento
    December 10, 2010 at 4:29 pm
    Hi mike
    Does’nt make any difference if I render 5 seconds or 1 hour.
    In the project I’m trying two options:
    NTSC DV Widescreen (720×480; 29,970 fps) Lower Field First
    HDV 1080-60i (1440×1080; 29,970 fps) Upper Field First
    My clips ware capture in Vegas, from my Canon Vixia HV30 1440×1080 60i like my source footage
    The Properties of each clip was Upper Field First
    I’m seeing this in the file rendered. So, after burn the DVD, too.
    Márcio Nascimento
  • Nigel O’neill
    December 12, 2010 at 7:02 am
    Mike
    PAL DVDA, rendered to m2t. I changed the quality slider to 31 (default was 15) and project settings to best (default was good).
    Original project is 1080/50i. Customer may request bluray output, hence I edited in HDV.
