Activity Forums Adobe Premiere Pro something wrong in capture
  • something wrong in capture
    Posted by Paul Patton on April 4, 2012 at 3:01 am
    I have captured 5 tapes with no problem using 1080i 60frames per second preset. on the 6th tape the frame rate once the captured footage is in the bin is 119fps. 56 minutes of footage captured from tape, playing fine on capture from camera. It shows 13.56 time in length when looking at interpret footage. I have tried to capture this same footage in a different project with the same results. The speed in playback in Premiere is ramped, but doesn’t seem to play at nearly 3 times as fast maybe 30% faster
    I am using Premiere Pro CS4 on a Mac, never had this problem before any suggestions
    Paul Patton replied 14 years, 5 months ago 1 Member · 1 Reply
  • Paul Patton
    April 4, 2012 at 10:31 am
    problem was in the camera, not Premiere. Used different camera capture was fine
