Activity › Forums › Maxon Cinema 4D › Something like photoshops layer comps?
  • Something like photoshops layer comps?
    Posted by Daniel Hopkins on March 25, 2017 at 4:04 pm
    Hi All,
    I’m working on a project with an extremely high poly model(s).
    I’m running into vram issues with octane and I’m looking for a clean way to manage things.
    In a nutshell I need to stop things from being sent to the renderer if I know they are not in the view of the camera for this particular shot.
    Right now I do it manually, but I’m looking for some way that I can sort of record the state of many objects render visibility.
    Photoshop has the layer comps palette where you can turn on and off layers and then record that as a state.
    Any advice welcome.
    Adam Trachtenberg replied 9 years, 6 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    March 25, 2017 at 10:40 pm
    You can do this either with the layer manager or the takes manager.
  • Daniel Hopkins
    March 28, 2017 at 7:59 pm
    Thanks for the info. I haven’t had much luck with the layer manager by itself, maybe I need to learn the takes manger.
    In the meantime I found this plugin from cineversity.
  • Adam Trachtenberg
    March 28, 2017 at 11:33 pm
    That’s pretty nifty, I hadn’t seen it before.
    The Takes system is pretty powerful if you take the time to figure it out.
