Activity Forums VEGAS Pro Something is wrong with the track
  • Mike Kujbida
    February 21, 2016 at 10:01 am
    That’s called the “expanded edit mode”.
    To exit expanded edit mode and return to the previous window layout; perform any of the following actions:
    * Choose Edit > Select > Exit Expanded Edit Mode.
    * Press 5 on the numeric keypad.
    * Double-click the event edge.
    * Press Esc.
  • Jorma Nippala
    February 21, 2016 at 11:38 am
    Or you have Expanded track layers.
    If you do not see any red bracket to indicate an event edge and the tricks above do not work, try right-clicking the track header and deselect Expand Track Layers. And double-clicking the vertical scroll bar will mimimize/restore the track heights.
