Activity › Forums › Adobe After Effects › something I’m trying to achieve with the comp edge
Posted by Greg Foreman on March 30, 2011 at 12:42 pmI’ve tried doing a search for this but its a little hard to put into words for a text search…
I’m trying to animate objects so that when their pixels leave the composition edge they reappear on the opposite side. So for instance if I had an object moving left, as it leaves the composition the pixels enter from the right hand side of the same composition… Like when pac-man leaves through the left side of the screen and enters from the right.
Is there an easy way to achieve this on after effects?
Steve Hardie replied 10 years, 10 months ago 6 Members · 8 Replies -
Chris Buttacoli
March 31, 2011 at 12:21 amWell, off the top of my head I can think of the OFFSET filter. Applied to an adjustment layer over the object being animated, you can set the center point to zero on the X axis and now the object will behave as you wish side to side. HOWEVER, the effect will break down at the middle of the comp where the true edges are now. So not sure if this is the right way to go about it. Hmmmm.
Tudor “ted” jelescu
March 31, 2011 at 12:11 pmI do not have the means to test this now, but I wonder if applying Motion Tile to your moving layer will do it.
Tudor “Ted” Jelescu
Senior VFX Artist -
Joey Foreman
March 31, 2011 at 2:00 pmTry CC Repetile. 1st Precompose your layer. Apply the effect, then depending on which side you want the layer to wrap in from, set the Expand Right or Expand Left to be the width of your comp for one wrap around. Set those to higher multiples (double, triple, etc.) if you want it to repeat. Then animate the position of the precomp.
There are also several presets in the effect you can experiment with.
Joey Foreman
Editor/Compositor/VFX Artist -
Tudor “ted” jelescu
March 31, 2011 at 2:30 pmI tried the idea I suggested earlier and it works.
Set your shape/object that you want to animate in the middle of your comp. Precomp that layer. Apply Stylize/Motion Tile. You need to set the width and height of the tiles in order to determine how many tiles you get in each direction (x and y). Depending on how many times you need your object to come in the frame after it goes out and on the size of your comp those values will change.
Also, depending on the way you want the object to come back in the frame (as soon as part of it goes out at the top the same amount comes in at the bottom- default setting, precomp size the same as master comp- or the object does not come in at the bottom until all of it goes out at the top of the frame, in which case you need to chage the size of your precomp, making it bigger – add the width and height of your object in pixels to the size of the initial frame).Tudor “Ted” Jelescu
Senior VFX Artist -
Brian Charles
March 31, 2011 at 2:35 pm -
Joey Foreman
March 31, 2011 at 2:46 pmSure, Brian, do it that way if you want a simple and elegant solution. I was trying to make it kludgy and time-consuming!
Joey Foreman
Steve Hardie
November 22, 2015 at 12:27 amIf it had to be a “true” loop where the parts of the object that leave the right of frame enter the left, is there a way to script that?
i.e. as the point where the pakman id half way out on the right, halfo of him would already have appeared on the left?
