Activity Forums VEGAS Pro Someone please explain why Vegas does bad streaming
  • Someone please explain why Vegas does bad streaming
    Posted by Jerry Waters on December 28, 2006 at 6:02 am
    if you apply FX? I’m using Magic Bullet film looks on footage and it looks great on DVD but if I try to encode it to a streaming wmv or QT file it looks like hell. If there is no FX it seems to be better but I can’t get it to look good with FX out of Vegas.
    JerryW
    Jerry Waters replied 19 years, 8 months ago 2 Members · 2 Replies
  • Dan Achatz
    December 28, 2006 at 7:20 am
    Vegas uses the tools supplied by other software makers to encode the streaming files.
    You need to know how to get the best out of those tools.
    Vegas allows you to encode Windows media files in hundreds of different combinations. The same is true in QuickTime.
    If your WMV files don’t look good, try increasing the bit rate. Also, you can choose a variable bit rate, or you can do a two pass consatnt bit rate.
    You did not say what you were encoding for( The web or for some other reason). I can tell you right now that you can encode a WMV 1080i or 720P file that will blow your socks off. All you have to do is set up the encoder to do it.
    Here’s a sample. https://www.filmguideseattle.com/images/jrcc720.wmv
  • Jerry Waters
    December 28, 2006 at 2:11 pm
    Thanks. This is what I was shooting for, smaller file, lots of detail:
    https://link6.streamhoster.com/?u=idalexed&p=%2FNineveh%2FTR+%231+20Kb.MP4&odaid=2559
    but someone had to help
    JerryW
