Activity Forums Panasonic Cameras someone deleted .txt file
  • someone deleted .txt file
    Posted by Sam Coates on May 24, 2006 at 10:02 am
    Hi Forum,
    about to start editing a TVC tomorrow, shot on a P2 today… producer tells me that someone has copied the contents of the cards accros to a firewire drive and ignored the .txt files.
    bummer
    I’m editing in FCP… and have successfully viewed P2 material in FCP using the acknowledged methods of importing footage…
    How can I get to the footage without the txt file?
    Very much appreciate your help.
    Sam
    Dan Montgomery replied 20 years, 4 months ago 4 Members · 3 Replies
  • Todd Mcmullen
    May 24, 2006 at 12:25 pm
    you can put the contents folder at the root level in your drive. I have also copied .txt file from one folder to another with success.
    Todd McMullen
    Flip Flop Films
    Austin
    Cinematography Forum Leader
  • Mike Schrengohst
    May 24, 2006 at 3:51 pm
    I think Jan from Panasonic said the .txt file was
    the info needed if a clip spanned two P2 cards.
    Otherwise you should not need it.
    You can edit the clips together
    manually.
  • Dan Montgomery
    May 25, 2006 at 10:18 pm
    Easy. Import the P2 volume(s) into HD Log–it doesn’t require the .TXT file. Select any clips you want and Export FCP XML. Creates the QT files ready to edit in FCP…plus your P2 clips are now all indexed for future reference. http://www.imagineproducts.com
    Video logging is just the beginning…
