Activity › Forums › Canon Cameras › SOMEBODY PLEASE
SOMEBODY PLEASE
Posted by Reggie Spires on February 4, 2008 at 8:09 pmCan the xh-a1 be used as a pass through to monitor work in adobe premiere and AE. If so how.
Donald Berube replied 18 years, 7 months ago 5 Members · 11 Replies -
Thaxter Clavemarlton
February 5, 2008 at 2:22 pmIf the video software is capable of monitoring “live” via FireWire:
Connect the FireWire from the computer to the the camera.
Connect a video monitor to the the camera’s S-connector or composite (yellow) connetor.
Connect amplified speakers to the camera’s audio output jacks.Turn on the camera (in VTR/Playback mode).
Open the video software.
Reggie Spires
February 5, 2008 at 2:51 pmDoesn’t work … The stupid thing is that it worked with a 200.00 camcorder but won’t work with a 3k one…
William Busby
February 5, 2008 at 6:03 pmYou must be doing something wrong. Make sure the a/v I/O switch for composite connections is set for output.
Reggie Spires
February 5, 2008 at 7:15 pmWhere is this switch .. in the camera settings .. I have been through them a hundred times. I can get a signal to the monitor when I play a tape from the camera but not when I open adobe AE PPro
William Busby
February 5, 2008 at 8:31 pmbehind the terminal cover. Actually it doesn’t say in or out… I was doing this from memory (which is dangerous :)) It switches from V2 (bnc) or the A/V1 terminal. Page 99… at least in the pdf manual.
Warren Morningstar
February 7, 2008 at 12:42 amTry the av-dv button on the remote control. Haven’t done it myself with my AH X1, but that’s how it works with my other Canon cameras…
Donald Berube
February 9, 2008 at 5:02 pmHi,
Are you trying to monitor Standard Definition DV from the XH A1 -or- are you trying to monitor HDV in real time as you edit?
Please do let us know asap so we can help you out.
– Don
DONALD BERUBE
https://noisybrain.com
https://www.bosfcpug.org
https://fcpugnetwork.org -
Reggie Spires
February 10, 2008 at 8:03 pmTrying to Monitor AE time line.. but I have also tried to monitor Ppro Standard and HD and neither works… I did this with a cheap Sony camcorder before and it worked fine
Warren Morningstar
February 10, 2008 at 8:21 pmI just connected my AH X1 to Premiere Pro and it is displaying SD output on both the viewfinder and external monitor. I don’t think that you can pass HDV video back up the firewire to the camera.
One thing to watch out for – fire up Premiere before you connect the firewire to the camera. Otherwise the camera will stay defaulted to what it was doing before – If you were passing HDV, the camera won’t switch to DV.
