Activity Forums DaVinci Resolve Some small things that bother me in UI
  • Some small things that bother me in UI
    Posted by Margus Voll on March 25, 2014 at 5:54 am
    I have met with those issue few times.
    Maybe it is just me but it is annoying in a sense.
    If i add parallel nodes on top of each other in some point there is to much of them
    lets say 16 or 18 on top of each other and the last one goes out of “screen” in node area.
    Even if i zoom totally out or try to move node area the last node is still out of screen.
    Would it be possible to make node area “infinite” or just zoom to fit no matter how many nodes?
    Second thing is keyframe area. If many nodes and i will turn on lets say last ones animate key
    and try to animate something the keyframe window scrolls up to node 1.
    I specifically wanted to manipulate node 13 but it does jump up to the node 1 every time i adjust something. Like there is forced auto scroll up that should work only once when you go to the shot
    or when you open your project.
    Anybody else seeing this ?
    I have met those little ones many times now as my parallel node trees are expanding fast.
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 10, OSX 10.8.5
    MacPro 5.1 2×2,93 24GB
    GUI 4000 / GPU GTX 780
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
    Margus Voll replied 12 years, 6 months ago 2 Members · 2 Replies
  • Martin Sansom
    March 25, 2014 at 3:04 pm
    Couldn’t agree more, really annoying. The parallel nodes issue can be avoided by selecting a node lower down the tree and then adding a new parallel node which will appear next to the one you selected.
    The whole keyframe/dynamics area of Resolve needs a re-boot, gang boxing of keyframes with the option to delete/copy/move as well as an expanded view like custom curves would be a start.
  • Margus Voll
    March 26, 2014 at 7:46 am
    I actually meant if those things could be changed simply and not the new features.
    In my mind the seem simple to fix but i do not know the actual case.
    Margus
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
