Activity Forums Apple Final Cut Pro Legacy Some slideshow questions
  • Some slideshow questions
    Posted by Stu Siegal on August 3, 2009 at 6:57 pm
    A friend has asked me to create one for a birthday party, looking for the best workflow for an sd dvd on a widescreen projector. Never actually done this before.
    Best Easy setup? Seq settings? Other threads point out correct scan size & recommend 24p, but cant find an easy setup recommendation.
    Also, I’ve set the still duration in the user pref to 15 sec., but everything still comes in as 12 seconds. Tried creating a new seq., but to no avail. I know I can adjust the duration by selecting all and right clicking on the timeline, but would like to know why the duration pref is not working.
    http://www.verite-media.com
    Bryan Dicerb replied 17 years, 1 month ago 3 Members · 4 Replies
  • Zane Barker
    August 3, 2009 at 8:08 pm
    Honestly the best way to do photo slideshows is not in FCP.
    Check out FotoMagico.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Stu Siegal
    August 3, 2009 at 9:01 pm
    Hi Zane,
    I’ve seen that recommended, but the project’s just a freebie, and I’d have no use for it otherwise. Might try the demo, though.
    Still don’t know why the still length import isn’t working.
  • Zane Barker
    August 3, 2009 at 9:05 pm
    [Stu Siegal] “I’ve seen that recommended, but the project’s just a freebie”
    Then just use iPhoto.
    There is no reason to sped hours key framing in FCP for something you are not getting any money for.
  • Bryan Dicerb
    August 4, 2009 at 11:15 am
    I just did one in iPhoto. Exported it as an HD QuickTime and then brought it into fcp to freshen it up. Saves a ton of time and still looks great.
