Activity Forums Adobe After Effects Some quick codec advice please.
  • Some quick codec advice please.
    Posted by Malcolm Desoto on August 21, 2007 at 1:43 pm
    Hey, I’m in a bit of a pinch here. My AE export didn’t work last night which means that I have no video this morning.
    What’s a codec I could use (exporting from AE) that’s quick and will look decent? It only has to look good on like a 5in display.
    Please help! I only have two hours.
    Oh, the spot is 30 sec and it takes (estimated time) 18 hrs to export when set to best, losless.
    Malcolm Desoto replied 19 years, 1 month ago 2 Members · 3 Replies
  • Malcolm Desoto
    August 21, 2007 at 2:04 pm
    okay. I’ll try that.
    Sorry, when I said “export” I was refering to the render queue.
    I’ll try those settings though.
  • Steve Roberts
    August 21, 2007 at 2:14 pm
    Render at Best Quality, Half res, 15fps (if 30 is normal) to save time if you want 320×240, 15 fps.
    Otherwise, if you do Best, Full res, 30 fps, it won’t matter what codec or output module size you use — it’ll still be an 18 hour render.
  • Malcolm Desoto
    August 21, 2007 at 2:23 pm
    Okay, I’ll give it a shot.
