Activity Forums Adobe Premiere Pro Some questions on basic editing
  • Some questions on basic editing
    Posted by Paolo on October 4, 2005 at 10:11 pm
    1. Why “ripple delete” command is not alwas available? When i work on a complex project with multiple tracks i have to lock all the track but one to make a ripple edit after i select a clip or an empty space.
    2. I have a timeline with three clips, i want to delete clip two without use the mouse so: with keyboard shortcut i go to the cut between clip one and clip two, i set IN, go to next cut between clip two and clip three, i set OUT. I make Extract but: why the selection include the first frame of clip three? I want only cut clp two and not also the first frame of clip three! Everytime i must go back 1 frame before set OUT point! I think this a wrong behavior of the program.
    3. There is not keyboard shortcut to select the clip where the CTI is place?
    Hector Melendez replied 20 years, 11 months ago 3 Members · 3 Replies
  • Craig Howard
    October 5, 2005 at 12:26 am
    Q.1 Just target the track that you intend to ripple delete a clip from. No need to lock the others.
    Q.2 Select the clip you want to delete (with the mouse) and delete or ripple delete it ( Why set in and out points unless it is part of a clip you are talking about)
    Q.3 I do not think there is keyboard shortcut to do this. How would it know what clip in the case of multitracks.
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Craig Howard
    October 5, 2005 at 1:02 am
    Sorry – my post above I have misinformed you. Ignore my suggestions fo Q.1 and Q.2
    Craig
    Auckland
    New Zealand
  • Hector Melendez
    October 5, 2005 at 2:12 am
    Ripple could be not available if you also don’t select the audio together when cutting. This is to avoid unsync remaining A/V tracks. So be sure you have unlock the A/V you want to cut and in the Timeline extreme left see if are darker too.
    To delete the clip just select it and hit X (don’t remember if I customized my keybooard to do this)
    Hope this help you
