Activity › Forums › VEGAS Pro › Some questions about Sound Forge in you Vegas +DVD workflow?
  • Some questions about Sound Forge in you Vegas +DVD workflow?
    Posted by Tevya Washburn on August 3, 2006 at 2:28 am
    I’m looking at getting Sound Forge to fit into my Vegas+DVD workflow, and was just wondering if any of the rest of you used this combination, and if so, what do you like about it? How does it work with a typical project? Etc.?
    I used to use use what is now Adobe Audition back when it was made by Syntrillium, and my instinct is to go back to it. However, I assume that Sound Forge is more likley to integrate a little better with Vegas. Has anyone used the two programs, and how do they compare (to each other and on integration in your workflow)? Two things I’ve noticed: Audition is $50 more, but has advanced noise removal built in. Sound Forge doesn’t, but then is cheaper.
    The thing is, I don’t use an audio application extensively for most stuff–partly because I don’t know as much about audio as I should–so I’m just trying to decide what is best, and if I really need an audio editor anyway, since Vegas does a decent job of handling audio anyway. This is why I ask the question about it fitting your workflow. Thanks.
    –the Fiddler
    Tevya Washburn replied 20 years, 1 month ago 6 Members · 8 Replies
  • 8 Replies
  • Tevya Washburn
    August 3, 2006 at 4:32 am
    Just thought of something else: does Sound Forge have surround mixing/encoding. I know Audition does.
    –the Fiddler
  • Ted Snow
    August 3, 2006 at 7:43 am
    Vegas has surround sound capabilities. Vegas is one of the best audio editors around in my opinion.
  • Allen Zagel
    August 3, 2006 at 9:57 am
    Vegas will handle most of your audio needs. I have Sound Forge + Sony’s Noise reduction plug-in. Yea, expensive. For the few times you may need a seperate audio program, you can right click on the sound track and open it directly into Sound Forge. Don’t know if you can do it with Audition.
    Sony’s noise removal program was a bear for me to learn. I’ve seen some videos on Audition and personally if I were going to buy one today, I’d probably look really close at Audition, because the noise removal is included……
    But then I found out about an open source Audaccity
    https://audacity.sourceforge.net/
    …and that changed my whole outlook.
    Allen
    ASX Media Productions
    https://www.asxvideo.com
  • Jerry Waters
    August 3, 2006 at 12:55 pm
    What I like about the two together is if you click on “open a copy in Sound Forge” and edit it, when you hit “Save” it will insert the edited material as a “take” and then in Vegas you can right click that clip and choose that or a different “take” you want. (The saved file is automatically inserted as the take in use.)
    JerryW
  • Tevya Washburn
    August 3, 2006 at 6:05 pm
    Thanks guys. Anyone else want to weigh in?
    I’m familiar with Audacity, but it’s fairly limited in its abilities, or was last time I used it….
    –the Fiddler
  • Anoni Moose
    August 3, 2006 at 6:59 pm
    [JerryW] “What I like about the two together is if you click on “open a copy in Sound Forge” and edit it, when you hit “Save” it will insert the edited material as a “take” and then in Vegas you can right click that clip and choose that or a different “take” you want. (The saved file is automatically inserted as the take in use”
    I think it does the same thing if you configure Vegas 6 to use some other external editor such as Audition [formerly Cool-Edit Pro]. In the options, an external audio editor can be configured instead of Sound Forge. The vegas menu won’t have the program’s name (will be a generic reference) like it would with Sound Forge, but I recall it works the same way.
  • Josh Meredith
    August 3, 2006 at 10:29 pm
    I’ve used just about every version of Cool Edit, Pro & otherwise, until it turned into Audition. I also use Sound Forge. I’ve got them both on my Vegas computer, and use both a lot. I find Cool Edit to be much better for extremely detailed editing of the waveform, such as removing breaths, etc.. However, that is probably more personal preference than something lacking in Sound Forge. I rarely use Cool Edit’s multitrack function anymore, since I started using Vegas.
    I do love Soundforge for some things, though, like EQ and other filters. Last night I used it’s paragraphic EQ to remove an occasional low end rumble during an interview that I couldn’t seem to isolate with Cool Edit’s EQ.
    Cool Edit’s (and Audition’s) noise reduction works a lot better for me, too. Sound Forge claims to have NR, and I’ve messed with it on several occasions, but I can’t figure it out. Which is strange, because usually when I’m using software that I can’t figure out even after many attempts, it comes from Adobe!
  • Tevya Washburn
    August 11, 2006 at 4:03 am
    LOL! I hear that man. Though I do prefer Photoshop to any other image editor. Well that’s good to know. I just might have to go back to CoolEdit just for comfort’s sake. I dunno though, maybe for now I’ll just make due with Audacity and wait ’till the come out with the next version of both those packages.
    –the Fiddler
