Activity Forums Apple Final Cut Pro Legacy Some Proxy files do not fill Canvas and Viewer
  • Some Proxy files do not fill Canvas and Viewer
    Posted by Melissa Mcleary on September 24, 2011 at 2:23 am
    I am editing a 16mm short film with Final Cut Pro 7.0.3. From telecining we were given two Uncompressed 10 bit Quicktime files at 25fps, Upper field first, frame size 1920×1080.
    Using Media Manager and the Recompress Media function I created two proxy files (Apple ProRes 422 (Proxy) 1920×1080, 25fps, Square Pixel aspect, no field dominance) keeping the original reel names.
    I have been working with Apple ProRes 422 (Proxy) sequences that have a frame size of 1920×1080 (25fps, Square Pixel aspect, no field dominance).
    During the editing process I noticed some vision in my sequence did not fill the entire screen (leaving a black border). I have double checked all my vision in the timeline is scaled at 100. The majority of clips are correct in appearance. Only some clips in my sequences are effected not the whole proxy reel.
    How would I make all clips a uniform size?
    Any advice would be greatly appreciated. Thank you!
    Eric Strand replied 14 years, 12 months ago 2 Members · 4 Replies
  • Eric Strand
    September 24, 2011 at 2:36 am
    Well I’m not sure why it would only be some clips, but you could try right clicking on a clip you know looks right, then copy. Then select the clips that are displaying incorrectly, right click and select paste attributes, and select scale? I forget what the exact label is but you seem pretty knowledgeable about FCP.
  • Melissa Mcleary
    September 24, 2011 at 2:44 am
    Hi Eric
    Thanks for the tip. I tried that but it didn’t have any effect.
    Thanks for your help though
  • Melissa Mcleary
    September 24, 2011 at 2:48 am
    Hi Eric
    All I had to do was select the incorrect clips. Right click -Remove Attributes
    And remove Distort
    Thanks for your advice!!
  • Eric Strand
    September 25, 2011 at 1:11 am
    Great! Glad you were able to figure it out.
