Activity Forums VEGAS Pro Some flickering after render to bluray
  • Some flickering after render to bluray
    Posted by Chris Evans on July 14, 2014 at 7:25 pm
    Just rendered my latest mammoth project to bluray. It looks good on the whole, but there’s a couple of issues I have had. I am thinking it is caused by some Magic Bullet colour correction that I have done, and I was wondering if I could adjust anything to remove or reduce the flicker.
    First, one some clips where the background sky is really bright (almost white) there is flicker in the bright sky area. This only causes a problem in maybe three or four clips. For these clips, I have applied the “vivid” colour preset in magic bullet.
    Second, I have a couple of clips using the monochrome highlight red magic bullet effect. This causes the whole picture to flash on and off quickly a couple of times.
    The simple solution would be to just remove the effects on those clips, but it would be nice to be able to understand what is causing the problem.
    Thanks once again for any help.
    Chris Evans replied 12 years, 2 months ago 2 Members · 6 Replies
  • Steve Rhoden
    July 14, 2014 at 9:50 pm
    Which version of Sony Vegas are you using?
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Chris Evans
    July 14, 2014 at 10:24 pm
    Sorry, forgot to say. Its 11
  • Steve Rhoden
    July 14, 2014 at 11:06 pm
    There was a known issue for this in Vegas 11 yes.
    Are you using the last update for vegas 11?
    (Build 701 64bit) or (Build 700 32bit)…I think it was fixed.
    https://www.sonycreativesoftware.com/download/updates/vegasfamily
  • Chris Evans
    July 15, 2014 at 8:10 am
    Thanks Steve. I will update. A bit scared of updating at such a late day in the project. Are all settings and preferences retained after an update?
  • Steve Rhoden
    July 15, 2014 at 8:24 am
    Everything will be retained after the update. This late release
    update was highly recommended for all vegas 11 users at the time.
  • Chris Evans
    July 17, 2014 at 10:49 pm
    Well I upgraded to 12 and the flickering on the red highlight effect remains! Any more ideas?
