Activity Forums Apple Final Cut Pro Legacy some FCP questions
  • Jerry Hofmann
    July 15, 2005 at 3:45 am
    Re rendering won’t degrade the clips.
    If you deinterlace, you’ll lose resolution, because you are throwing away 1/2 the image. (one of the two interlaced fields).
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
