Activity Forums Blackmagic Design Some clarification regarding the Intensity Shuttle
  • Some clarification regarding the Intensity Shuttle
    Posted by Adam Findlay on December 7, 2011 at 12:52 am
    Hi. I’ve been looking at getting one of these for the purposes of streaming PC games, but having checked the specs I’m a little unclear on something and to be frank, i’m not comfortable taking the word of people on youtube who clearly struggle with the concept of a directshow filter.
    My plan is this: I have 2 fairly high spec machines. 1 of the systems will be running the game, connected to a monitor via an HDMI cable (with the Shuttle inbetween) at 60hz 1080p, and the other will have the shuttle connected and will be streaming the actual video itself.
    Although I only plan to stream at either 720p or 1080p (30fps), I’d still like the image displayed on the monitor to be a 60hz signal, is this possible?
    Also just to check, is there any substance to the claims I’ve read that this box only works with a particular set of motherboards? Both of the systems I will be using are laptops (I’ve purchased a USB 3.0 ExpressCard for the streaming system), so that may be a problem.
    Cheers, Adam
    Mike Squires replied 14 years, 7 months ago 3 Members · 4 Replies
  • Ethan Cord
    December 7, 2011 at 7:57 am
    I’ve used/tested the Intensity Shuttle on various different hardware. The main problem I came accross was when using any USB 3.0 controller other than the NEC/Renesas (I’ve even tried the Fresco Logic FL1009 and it failed miserably).
    Also power saving technologies can prevent the Shuttle from working. On Intel P67, Z68 and X79, enhanced ‘C’ states (C3/C6/C7) must be disabled. On AMD 890/990FX, with a Phenom II CPU, C1E must be disabled, with an FX CPU it can be left enabled. Lastly, PCIe link power saving must be disabled in the Windows 7 power options.
    Getting the Shuttle working on a Laptop is tricky. A USB 3.0 ExpressCard isn’t going to have enough bandwidth, BlackMagic’s own support page states: “ExpressCards for notebooks are not supported and will not work. The bandwidth they currently support is not suitable for Intensity Shuttle, UltraStudio Pro or Pocket UltraScope.”
  • Adam Findlay
    December 7, 2011 at 3:08 pm
    Ah, good thing that USB 3.0 express card was pretty cheap then.
    Do you know of any other devices that do what I’m looking for? I do get the feeling that Intensity shuttle was a touch overkill for my needs, but I hadn’t come across anything that did quite the same job.
  • Adam Findlay
    December 7, 2011 at 3:43 pm
    Also just to check I understand correctly, the support hardware is the regular enterprise AV “we can only guarantee it works on this particular hardware” approach? And if I’m understanding correctly, the motherboard issue was more to do with the USB 3.0 controller they had?
  • Mike Squires
    February 22, 2012 at 2:46 am
    It works on my Asus G53SW, which uses the Fresco FL1000 Series Controller. Fresco released a new driver back in mid-December, maybe that fixed the problem.
