Some Avid Questions
Hi folks, I’ve been out of the Avid loop for many years now, but there is a possibility I may get some work at a local station that uses it. I would imagine they are using Newscutter, but a trip over to the Avid site seems to show Avid has discontinued Newscutter and are now consolidating everything into Media Composer. Never having used Newscutter I don’t really know how it was different from the main app, and at this time I don’t know if this station has updated to Media Composer 7/8 or are still running an older version of Newscutter.
So I’m not sure if I should just download the trial Media Composer and screw with it to re-familiarize myself with it, or try to find a copy of Newscutter and mess with that instead.
I’m curious about something however. It appears Avid is forcing you to re-render raw footage into their proprietary DNxHD codec in order to work within the editor, rather than work directly with the native footage. Is this correct? This strikes me as rather inefficient. I can’t imagine networks actually putting up with such a time consuming process like this, so some clarification on this is appreciated.
I worked in the early part of the 2000s with Xpress DV, and I thought Avid was a great cuts-only app, really fast like that, although rather dismal if you really wanted to get sophisticated. Hopefully they’ve modernized the app to have better flexibility than the stuff I worked with.
So I’m curious to hear what present-day users have to say of these things. Thanks in advance for your replies.
