Activity Forums Apple Final Cut Pro Legacy some audio normalization advice?
  • some audio normalization advice?
    Posted by Nelson May on May 25, 2011 at 9:30 pm
    I know STP, but I am not good enough with it to work with 16 20 minute talking head video clips to hit my deadline. I was given these video clips and the audio was recorded at about -30 to -24db. I usually add the compressor effect in FCP just to dial everything in a bit. I want to get this audio up to about -6db peak for DVD authoring. Can someone walk me through an effect or set of effects to get my audio levels up. If I just push them up in the time line I barely get to -12db.
    This was done on a lapel mic and I don’t hear a lot of room noise or hum, so can you help with with normalization after I apply compression? Is normalization the way to go here?
    MBP 2.4GHz 4MB RAM, 30″cine, MAC PRO 2.6 8 core 6GB RAM, Mbox, Neumann TLM-103, FCP HD 7. Pro Tools 8, Adobe Creative Suite, Reason 3.0, Macromedia Studio, ProAnimator, HVX200 with Firestore v4.0
    Alan Okey replied 15 years, 3 months ago 3 Members · 3 Replies
  • David Roth weiss
    May 25, 2011 at 9:33 pm
    Download and try Levelator, it’s free all over the Web. You just drag and drop an audio file on top and check the result when it’s done, which happens quite quickly.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Nelson May
    May 25, 2011 at 9:55 pm
    Thanks David. This thing works well. I have to pull back my audio level about 2db because I am hitting the red in a few areas, but this did the trick.
    Appreciate the help.
    Nelson May
  • Alan Okey
    May 25, 2011 at 9:58 pm
    Adjusting levels on tracks in the timeline only gives you +12dB of gain, whereas adding a gain filter allows you to add much more. Add a gain filter before the compressor filter in the effects chain and boost to taste. Also be aware that adjusting gain in the timeline is post-filter, so if you set a limiter threshold to -6 and then boost the levels in the timeline, you’ll go over -6.
    I dislike the audio filters in FCP. Much of the time there is no realtime feedback in payback while adjusting parameters.
