Activity › Forums › Adobe After Effects › Some artificial edge appearing around a true-alphaed layer in compositing
  • Some artificial edge appearing around a true-alphaed layer in compositing
    Posted by Mostafa Talebi on September 21, 2011 at 6:25 pm
    hello
    I have made these simple renders in autodesk Maya 2012 (Mental Ray)and saved them in png format. all the alpha and masking rules are observed during the compositing phase, and everything looks fine BUT!!!!! there is (as marked) a black edge around the spheres. WHY?
    also there is no blurring applied to layer’s alpha.
    Image and video hosting by TinyPic
    THANKS
    Ben G unguren replied 15 years ago 2 Members · 3 Replies
  • Ben G unguren
    September 21, 2011 at 6:30 pm
    Sounds like you need to change the alpha type from straight to premultiplied, or vice versa….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Mostafa Talebi
    September 21, 2011 at 6:38 pm
    thank you much………
    the name is too familiar, where I can set the setting for premultiplied alpha?
  • Ben G unguren
    September 21, 2011 at 10:38 pm
    Select your footage in the project window, right click, choose “Interpret Footage–>Main…” (hotkey cmd+opt+G) then change your alpha type and see if it fixes it.
    Ben Unguren
