Activity Forums VEGAS Pro Some advice on rendering avchd
  • Some advice on rendering avchd
    Posted by Nate Bru on March 25, 2010 at 3:46 am
    I have home videos I have recorded on my Samsung HD camcorder (model: SC-HMX20C). These are only family videos I will be keeping for the memories. I have been editing them in Vegas Pro 9.0c, and cutting out the unwanted parts. I realize the Pro version is probably overkill for what I am wanting to do, but I’m using a dual-core laptop and was having issues with Platinum which were totally resolved using Pro without making any system changes.
    And finally to my issue: I want the best output format and settings to use in Vegas to preserve the videos for playback on my PS3 and computer now, and to be able to easily burn these to Blu-ray in the future without needing to go back and re-edit the old raw footage. I have tried several of the Sony AVC output settings, and most I can get to play as desired. I just want to know that I am encoding these at top quality and not degrading the files to the point of needing to re-render later. With my laptop, it takes about 7 hours to render an average 30 minute clip, and obviously frustrating when they won’t play correctly afterwards. I may have overlooked a guide somewhere on this topic, but I would think there can’t be a guide for every camera and file format.
    Here is the info from one of the files I’m importing in Vegas to make a final video. I normally record all my home videos with these same file settings:
    General
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 369 MiB
    Duration : 4mn 50s
    Overall bit rate : 10.7 Mbps
    Movie name/More : SKY02 Digital Camera
    Encoded date : UTC 2010-03-11 19:20:54
    Tagged date : UTC 2010-03-11 19:20:54
    Origin : Digital Camera
    TAGS : UNG DIGITAL MOVIE
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L4.0
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 4mn 50s
    Bit rate mode : Variable
    Bit rate : 10.5 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 59.940 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.085
    Stream size : 364 MiB (99%)
    Language : English
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 4mn 50s
    Bit rate : 127 Kbps
    Nominal bit rate : 128 Kbps
    Maximum bit rate : 192 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Stream size : 4.41 MiB (1%)
    Language : English
    From what I have read, the MP4 format is already compressed and so I don’t want to further compress/degrade the files further. I attempted to render the video using the same output settings as the input files. The main difference being changing the output to 59.97fps instead of 29.97fps, and the rendered video was unplayable on my PS3 or laptop. So the settings I have been commonly using are:
    Audio: 192 Kbps, 48,000 Hz, 24 Bit, Stereo, AC3
    Video: 29.970 fps (NTSC), 1920×1080 Upper field first, YUV, 12 Mbps
    Profile: High
    Entropy coding: CAVLC
    Pixel Aspect Ratio: 1.000
    Video Rendering quality: Best
    Output format: m2ts
    My computer specs: (laptop)
    Pentium dual-core T4200 2.00 ghz
    Vista Home premium 32 bit
    3 gigs ram
    320 gig hd
    The files are playable at these settings. But again, I just want to make sure I’m not further compressing or degrading the video in some way. I am new to video editing, so assume I don’t know anything at this point.
    Thanks for any help,
    Nate
    John Rofrano replied 16 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    March 25, 2010 at 4:27 pm
    Use the Sony AVC render type with one of the Blu-ray templates. Don’t mess with any settings. Just use the Blu-ray templates that Sony provided and they will play on your PS3 and future Blu-ray without any problems. This will also maintain the best quality.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Nate Bru
    March 26, 2010 at 2:57 am
    Thanks for the response John. Two new questions I thought of:
    1- When I render using the Mainconcept AVC, it took 17 hours to render a 30 minute clip (over twice as long as Sony AVC). I need a faster computer asap. But besides that, the clip would not play properly afterwards, even on my computer. Why wouldn’t the resulting Mainconcept .mp4 file work better than the Sony .m2ts (which play fine), since the input files were Mainconcept .mp4?
    2- Since my original files were recorded at 59.94fps, is there not some drawback to rendering them at 29.97fps?
    These are both curiosities and not complaints. Thanks again for your advice.
  • John Rofrano
    March 28, 2010 at 2:39 am
    I have found that the Sony AVC render is better than the MainConcept one. I don’t know why. I just use the Sony one.
    There is no delivery format for 59.94fps. It should only be used for video that you want to slow down smoothly to 29.97fps. The current delivery standards are 29.97fps, 25fps, & 23.976fps. I wouldn’t shoot at a higher frame rate unless it was for special FX.
    ~jr
  • Nate Bru
    March 28, 2010 at 3:22 am
    thanks for you help john.
  • John Rofrano
    March 28, 2010 at 1:20 pm
  • Ben Longden
    March 29, 2010 at 7:35 am
    Hi John,
    Again thanks for this info.
    Using the blu ray burn option in Vegas, can you use , for example, a 4.7Gb disc as the recording media without a dedicated BluRay burner?
    Ben
    Do unto others…
  • John Rofrano
    March 29, 2010 at 12:26 pm
    Yes, you can use 4.7GB DVD media but the resulting disc format will be Blu-ray. This means that it will not be readable by your DVD burner after it is created. It will be a Blu-ray formatted disc on DVD media.
    ~jr
