Activity Forums Adobe After Effects Expressions SOLVED…I need to add 220 pixels from the right edge of the last character in the pre comp below…. any thoughts?
  • SOLVED…I need to add 220 pixels from the right edge of the last character in the pre comp below…. any thoughts?
    Posted by Henry Gaunt on August 17, 2016 at 12:53 am
    var width = thisComp.layer(index+1).width;
    var widthB = thisComp.layer(index+1).width;
    var offset1 = thisComp.layer(“Adjustment Layer 4”).effect(“Slider Control”)(“Slider”);
    var offset2 = thisComp.layer(“Adjustment Layer 4”).effect(“Slider Control 2”)(“Slider”);
    x= thisComp.layer(index+1).transform.position[0]+offset1+width/2+widthB/2;
    y= transform.position[1]+offset2;
    [x,y]
    Henry Gaunt replied 10 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
