Activity › Forums › Blackmagic Design › Solved RS-422 problem with decklink studio card
Posted by Remco Wiekard on March 15, 2009 at 8:53 amA few weeks ago my company bought me a new Macpro with a decklink studio card. After installing Final Cut Studio I tried to connect to a Digibeta DVW A-500P. The decklink card said No Comm. After trying to connect via a standard Sony RS-422 cable still no Comm. I could connect to any other device (DV, XDCam, J3) so it had to be something with the protocol in the driver. After contacting BM support, they told me to connenct pin 2 to pin 8 and the other way around in the RS-422 cable. That indeed solved the problem. Ik hope sharing this info with new studio card users will help you.
MacPro dual Quad 2,8 GHz – 16 GB RAM – Blackmagic Studio – FCP 6.05 – OSX 10.5.5 – G5 2,0 GHz – 4 GB RAM – Decklink Extreme – FCP 6.05 – OSX 10.5.5
Robert Nicol replied 14 years, 3 months ago 9 Members · 14 Replies -
Bob Zelin
March 17, 2009 at 2:05 amI cannot believe that this worked. Every Sony VTR uses a “straight through” cable – pin 1 to pin 1, pin 2 to pin 2, etc, etc. This is every RS422 cable for every professional VTR since the linear video days.
the DVW-A500 Remote 1 IN port is a standard RS422 port. Cross wiring the pins does not make it work. I don’t know exactly what is going on at your place, but I cannot believe that you are going into the RS422 Remote 1 IN port on your VTR. A straight thru cable should absolutely work.
bob Zelin
Remco Wiekard
March 17, 2009 at 6:56 amI don’t understand why it works, but it does. The only thing I do know is that when I used a straight sony rs-422 cable, the studio card did not see a machine. Crosswiring solved that problem. Blackmagic gave me that solution and it solved the problem
MacPro dual Quad 2,8 GHz – 16 GB RAM – Decklink Studio – FCP 6.05 – OSX 10.5.6 – G5 dual 2,0 GHz – 4 GB RAM – Decklink Extreme – FCP 6.05 – OSX 10.5.6
Jay Cordova
March 24, 2009 at 10:36 pmWell, darned if I don’t have exactly the same problem. Just got a Decklink Studio, can connect to everything else EXCEPT the DVW-A500.
I hesitate to cross over the wiring for sure but am at my wits end. Gotta be something with the protocol in the Studio card, because the former Decklink card that just came out worked fine controlling all machines.
I haven’t contacted Decklink support. I can’t believe this crossover worked either, and the Blackmagic folks suggested this solution to deal with the A500? Hmmmmm.
Anyone else with the same problem – Decklink Studio won’t work with DVW-A500?
J. Cordova
Springboard Creative/Atlanta -
Remco Wiekard
March 25, 2009 at 12:14 pmhere is the original mail i got from B;ackmagic design.
“We believe that this may be a grounding issue, similar to your
customer who tried to ground pins together. The current solution is
we have a small RS422 pin map cable, which so far has shown to solve
the problem in our testing. This will need to be attached to the back
of the Decklink card, and then the RS422 cable run as normal.
This problem will now be examined further in hardware/firmware and an
appropriate solution found.”Pin out of the pin map cable is:
Cross pin 8 (Receive A) and pin 2 (Transmit A).
8 > 2
2 > 8MacPro dual Quad 2,8 GHz – 16 GB RAM – Decklink Studio – FCP 6.05 – OSX 10.5.6 – G5 dual 2,0 GHz – 4 GB RAM – Decklink Extreme – FCP 6.05 – OSX 10.5.6
Jay Cordova
March 25, 2009 at 4:22 pmThanks. So you have this crossover engaged, and are you still able to control other machines, or are you strictly hooked up RS-422 to the A-500?
J. Cordova
Remco Wiekard
March 26, 2009 at 6:20 amI’m still able to control any other machine (suchs as xd cam 1500, betacam J3, several DV decks). I am connected to a rs-422 switch in the machine-room.
This is just a temporary solution. I think that Blackmagic will speed up the proces of making a new driver to solve this problem. But in the mean time, I can connect to a DVW-A500MacPro dual Quad 2,8 GHz – 16 GB RAM – Decklink Studio – FCP 6.05 – OSX 10.5.6 – G5 dual 2,0 GHz – 4 GB RAM – Decklink Extreme – FCP 6.05 – OSX 10.5.6
Jay Cordova
April 2, 2009 at 6:19 pmWell, go figure. Switching pins 2 and 8 does indeed work. Thanks a ton.
I didn’t mention that not only could I not control the digibeta A500, but I had no machine control with the Panasonic HD-1200A either.
With the pinouts switched, I have control over all of the machines now (BetaSP 1800, Digi M2000, Digi A500 & Panasonic HD-1200).
I do not understand, and I’m an engineer type. At this point, though, I don’t need to. It works.
Thanks again.
So those of you with the same problem (or similar with other decks not mentioned here) might consider this “solution”, even though your engineering brain says “no”.
J. Cordova
Michiel Van haren
April 7, 2009 at 10:30 amI’ve got exactly the same problem here. No RS422 control with our DVW 500P digibeta deck.
Hopefully BM will fix this in an update soon! -
Martin Eberle
April 24, 2009 at 1:30 pmWell, the 7.1 upgrade didn’t solve the problem. That is really annoying, I am not really experienced with the cutting of cables. Shouldn´t Blackmagic supply it´s customers with a free cable to get everything working?
Martin Eberle
April 24, 2009 at 2:48 pmJust got a call from Die Agenten from Munich: Blackmagic will provide a cable but a software upgrade is ahead to fix the problem. Strange, didn´t Balckmagic test the remote or was it that they just didn´t care?
