Activity Forums Adobe After Effects Expressions [solved] Referencing layer hierarchy in expressions
  • [solved] Referencing layer hierarchy in expressions
    Posted by Nathan Clark on December 29, 2009 at 6:51 am
    Hello all,
    Can anyone help me out with the following?
    Is is possible to arbitrarily reference a value from the layer above in the timeline?
    For example:
    Layer 01. Controller Null
    Layer 02. Solid
    01. Controller has a “Scale” expression slider
    02. Solid scale is linked to “Scale” slider of layer above
    This way I can simply duplicate them (a lot) and the expression will always reference the above controller?
    This would save me a LOT of time
    Thanks!!
    On Point Cloud Nine
    Bruce Wainer replied 16 years, 8 months ago 2 Members · 2 Replies
  • Nathan Clark
    December 29, 2009 at 7:50 am
    Hey all,
    I was just getting my syntax muddled while searching the forums.
    I have since found the answer-
    using the index + 1
    On Point Cloud Nine
  • Bruce Wainer
    December 29, 2009 at 8:52 pm
    index+1 will reference the layer below, index-1 will reference the layer above (layers are numbered top to bottom)
