Activity Forums Adobe Encore DVD Solved: Could not create Dolby Digital 5.1 Surround Sound DVD (specifically targeting Blu-Ray)
  • Solved: Could not create Dolby Digital 5.1 Surround Sound DVD (specifically targeting Blu-Ray)
    Posted by Michael Buie on March 27, 2012 at 9:01 am
    Issue prelude:
    OK … I taught myself how to set up a sequence to point my Stereo and Mono Audio channels to the 5.1 Master Channel, to use the puck in the Surrround Sound space to create my mix, etc, etc. Good to go, right?
    Wrong.
    Ready to render and discovered I had to chunck down $295 for Surcode. :-/ grrrrrr!
    Done.
    Rendered fine, apparently, but when I imported into Encore, I no longer could hear my audio in Surround Sound. I could not adjust properties for DD 5.1 Surround anywhere in Encore. There were so many variations of this issue listed on the internet, I could not figure out what was wrong from googling.
    I gvae up and called tech support and told the Indian guy the problem I was having and what I was trying to accomplish.
    Now don’t get me wrong. I’m a software developer and work with some stellar programmers who are from India; I know anyone of any background can achieve anything. But, I had to go through a torturous script with a guy who knew NOTHING about this application.
    I subsequently went through a situation similar to this one:
    https://youtu.be/GMt1ULYna4o
    After asking me to hold (a good 15 minutes) he came back and told me I must not have used SurCode to encode the audio!
    Are you freaking KIDDING ME! I told you I just bought Surcode, dude!
    He made me do a lot of useless crap before telling me he would escalate the issue to someone with technical knowledge of Encore (duh) and I was stuck where I started, a torturous hour or more later.
    To make a long story short, here is the trouble-shooting I put in the ticket opened online for me, and the update I supplied when I finally decided just to burn a DVD regardless of whether I could hear the 5.1 channels in Encore or not.
    I am a meticulaous trouble-shooter at every step. Apparently that bit me. If I had ignored the fact I could not hear 5.1 sound at the Encore step, I would have come out with the finished product from the beginning. But, I would not have known this one little detail about not hearing it in Encore.
    1. Problem report and trouble-shooting
    – Dolby 5.1 surround sequence plays fine in Premiere Pro
    – Exports to .ac3 file from PrPro, no problem.
    – Imports back into PrPro and plays proper 5.1 surround audio
    – Import into Encore, the .ac3 file will only reproduce in stereo
    – Import .ac3 OR .wma 5.1 file from internet into PrPro or play with other media program, 5.1 correct.
    – Import .ac3 OR .wma 5.1 file from internet into Encore, only plays in stereo (channels directed at Left Surround and Right Surround
    will not play
    2. Update after discovering I really had no problem (except a certain sliver of knowledge)
    “I came back to post what I found so you guys won’t waste your time.
    Apparently, even though playback in the Encore Editor is only in stereo, as long as I do NOT allow transcode of the audio, when it builds the DVD, it processes the 5.1 streams correctly.
    So, I burned a Blu-Ray DVD and upon playback, the 5.1 channels were routed perfectly.
    It would be helpful if somewhere you guys noted that even though Encore preview of the DVD will not output 5.1 surround, it will encode the built DVD properly as long as a transcode of the audio in Encore is not allowed.
    Brian Berneker replied 13 years, 8 months ago 3 Members · 5 Replies
  • Michael Buie
    March 28, 2012 at 3:07 pm
    How about all that work getting a 5.1 Surround Sound DVD completed and the movie theatre only hooks up their Film Print Projector to the “Dolby Head” as they put it, not hte Digital Projector.
    Does anyone here know what that’s about? Is there some digging I can get them to do to help them change that?
  • Eddie Moore
    April 30, 2012 at 4:39 pm
    You, my friend, are a f***ing life saver!! I’ve been fighting with this for the past 3 days and my deadline is coming…
    One question: How do you change the settings so that it will NOT allow transcode? do you do that in the Premiere before sending it to Encore? or do you do it in Encore? where do I find it in the settings?
    Now, when I export, my Encore presents Dolby Stereo.
  • Michael Buie
    April 30, 2012 at 6:51 pm
    Actually, just do not force a transcode by right-clicking on any of the files and teling it to transcode.
    I don’t use the Encore linking from Premiere Pro project. I render the video and audio using the mpeg DVD presets (for SD or Blu-Ray DVD) in Premiere Pro, adjust quality as I desire and export. The produced output format does not require transcoding by Encore. (One of the PRODUCTIVE tech support calls I made to Adobe taught me this.)
    As a matter of fact, when you look at the properties of the assset when you import it into Encore, it will say “do not transcode”. Select your audio and video asset, right click for the dialog box and tell it to create New Timeline. They will appear on a time-line. Complete your normal Encore tasks (menus, chapters, First Startup, no orphans, etc), hit your Build button and go! It will be a lot quicker because it will not transcode, only order the files and write to disk. 🙂
  • Michael Buie
    May 1, 2012 at 7:00 am
    Here is a sample of how I set up the export.
    https://www.platinumproductionz.com/images/pp_full_dialog.jpg
    Here is a close-up of the specific sections you should pay attention to.
    https://www.platinumproductionz.com/images/pp_bd_sequence_settings.jpg
    Use the Export Foramt “MPEG2-DVD” or “MPEG2 Blu-ray”, depending on which disk format you are burning. These Export types will not require transcoding in Encore.
    (The ‘Match Sequence Settings’ check box is no longer checked because I modified the preset for max render quality, frame blending, etc.)
    If you are creating a Dolby .ac3 file and it still plays stereo, then you are likely not using the “Surcode for Dolby Ditital” preset.
  • Brian Berneker
    January 20, 2013 at 11:39 pm
    I started to read your post to try and find out how to get a 5.1 mix out of Audition and into Encore, but when I got that video I had to stop and almost pissed myself laughing…
    oh yeah, what was I here for again?
