Activity Forums Adobe Premiere Pro Solution To Lost Audio In Premiere
  • Solution To Lost Audio In Premiere
    Posted by Damien Mustaphi on November 30, 2009 at 5:46 pm
    Hey all,
    I just wanted to give you a solution to your problem. I’ve had it happen on many occasions. What you need to do is go into your EDIT/PREFERENCES/MEDIA and check the location of your MEDIA CACHE FILES and MEDIA CACHE DATABASE.
    If possible, set this to your root storage drive…in most cases D:/
    When you lose your audio on certain clips, go to the Media Cache folders and delete the .mcdb, .cfa, and .pek files. The .pek files are generated in the conforming process. You can try just deleting certain file extensions, but if it’s a new project that you are working on, I tend to clear everything and let Premiere re-conform all of the video files.
    I’m not sure what causes this, but I tend to notice it when I import files and immediately drop them into the preview monitor and start cutting…it might just be something within Premiere that is going wonky when I start doing too much before it has conformed all of the videos.
    This has happened on both my PC and MAC.
    I hope that helps for you.
    Damien
    Damien Mustaphi
    Interactive Multimedia Producer
    http://www.damienmustaphi.com
    Ann Bens replied 16 years, 9 months ago 2 Members · 1 Reply
  • Ann Bens
    December 1, 2009 at 7:13 pm
    Give Premiere a change and let the conforming and idexing etc. finish before editing. Premiere cannot do everything at the same time.
