Activity Forums Apple Final Cut Pro Legacy Solution to greyed-out Qmaster prefs problem
  • Solution to greyed-out Qmaster prefs problem
    Posted by Dan Marlow on December 11, 2008 at 12:22 pm
    After 3 days of pulling my hair out i have fixed my qmaster. This refers to the problem whereby after a crash whilst using the latest version of Compressor and qmaster from the pro apps update. It does not refer to the other ongoing problem whereby one must delete .plists after a crash.
    My solution has been to reinstall FCS2. I found this bit of freeware:
    https://www.digitalrebellion.com/fcs_remover.htm
    It seems to do a decent job of removing FCS2.
    This has worked for me. Hope it helps others. Merry Xmas
    David.halpern replied 16 years, 10 months ago 3 Members · 3 Replies
  • Alex Elkins
    December 11, 2008 at 2:32 pm
    Did you try Compressor Repair from Digital Rebellion? https://www.digitalrebellion.com/compressor_repair.htm
    I use that every time Qmaster misbehaves and it’s so far worked every time.
  • Dan Marlow
    December 11, 2008 at 2:53 pm
    Yeah, i have compressor repair. It fixes the general problem whereby qmaster freezes after a crash. I think all it does is delete the .plist files. I tend to do that manually.
    This fix is for the problem specifically related to the latest update. compressor repair and even a complete reinstall of compressor and qmaster doesnt fix it.
  • David.halpern
    October 22, 2009 at 2:44 am
    Hi, whatever I do Qmaster keeps “Options for selected service” greyed out: for any combination of boxes ticked or unticked makes no difference, also doesn’t matter whether its quick cluster with services or any other option too. I have used Compressor Repair to trash prefs repeatedly, plus restarted. Software update says I am all up to date. I am on OS 10.5.8, on a 2Ghz Intel Core Duo Macbook, 2GB 667 Mhz DDR2 SDRAM.
    any ideas???
    David
