Activity Forums Maxon Cinema 4D Solo in C4d Lite?
  • Solo in C4d Lite?
    Posted by Paul Roper on March 1, 2023 at 1:47 pm
    Is it possible to solo an object in C4D Lite? I cannot find the solo button anywhere! Note: I’m using Lite, not the full C4D (I know how to solo things in the full version – or at least I used to a few years ago when I last used the full version!)
    Usama Aslam replied 3 years, 6 months ago 3 Members · 2 Replies
  • Michael blaq
    March 5, 2023 at 9:42 pm
    Hi Paul,
    If you are not seeing it. You can use this keyboard combo to pull up the search, that is, SHIFT+C and you can search for “viewport solo” or use the wild card “solo“.
    Hope this helps. Cheers!
  • Usama Aslam
    March 22, 2023 at 5:38 pm
    Hi Paul,
    Unfortunately, the Solo button is not available in Cinema 4D Lite. It is a feature only available in the full version of Cinema 4D. However, there are a few workarounds you can try:
    Hide all other objects: You can select all other objects in your scene and hide them by pressing Ctrl + H (Windows) or Command + H (Mac).
    Create a new layer. You can create a new layer in the Layers Manager and move the object you want to solo to that layer. Then, you can select that layer and choose “Solo” from the Layer menu.
