Activity Forums Adobe After Effects Solids/Masks-based SD project, easy way to convert to HD?
  • Solids/Masks-based SD project, easy way to convert to HD?
    Posted by Ricardo Nichols on August 25, 2008 at 1:47 pm
    Hello.
    I recently built a rather involved animation that is entirely using shapes build from solids with masks applied. I did it all at 720 x 540 pixels but am now wishing I could create this as HD. To go back and rebuild all of this at a higher resolution would be a huge pain, so I’m hoping there is a way to just import them into an HD comp that won’t blur the lines of the solids.
    Does that make sense?
    When I’ve taken a comp with a solid into another comp and scaled up, it gets blurry. I was hoping it might handle it similarly to Illustrator where, because they are paths, they could scale without losing integrity.
    Anyone have some advice? I’m praying there is some trick I can do to make this a much simpler operation that it is appearing to lil’ ol’ me.
    Thanks in advance for any info.
    -Rolyn
    Matthew Woods replied 18 years ago 4 Members · 3 Replies
  • Jerry Renes
    August 25, 2008 at 2:51 pm
    You could Make a new 1920×1080 pixels HD Composition within your project > then drag the SD Composition into the HD composition and turn on the “Collapse Transformations” Switch. It looks like a litte sun. and it’s next to the Shy Layer switch.
    Good Luck!
  • Darby Edelen
    August 25, 2008 at 5:04 pm
    [Jerry Renes] “You could Make a new 1920×1080 pixels HD Composition within your project > then drag the SD Composition into the HD composition and turn on the “Collapse Transformations” Switch. It looks like a litte sun. and it’s next to the Shy Layer switch.”
    To expand on that, I’m pretty sure that you’ll need to turn the collapse transformations/continuously rasterize switch on for all of the solids in your original SD composition as well.
    Darby Edelen
    NVIDIA
    Santa Clara, CA
  • Matthew Woods
    August 25, 2008 at 8:02 pm
    Another trick I have used if you would prefer to keep all your layers in the hd composition, would be to parent any unparented layers to a new layer or null. Then change the composition settings to your hd format, then scale/move your new parent layer until things fit how you’d like. You can then unparent and get rid of the new layer if you so choose.
