Activity › Forums › Maxon Cinema 4D › Solid transparent volume
  • Solid transparent volume
    Posted by Frank Feijen on April 15, 2016 at 12:03 pm
    Is there a way to create a shader for an object, that shows a transparent silhouet of the object? Just lowering the opacity shows all the details inside. I only want to see the silhouet, nothing inside, no shading, but transparent….
    either with the standardrender or even better with octane
    Adam Trachtenberg replied 10 years, 5 months ago 3 Members · 2 Replies
  • Brian Jones
    April 15, 2016 at 3:12 pm
    if I understand your description turn off the Color and Reflectance channels and use Transparency – just set the color in transparency to something other than white, for only being visible with something behind it or with some Luminance to always see it – or a combo of Alpha and Luminance. That works as long as your object isn’t intersecting some other object or sitting on a floor or something, as long as there is a little separation it should work.
  • Adam Trachtenberg
    April 15, 2016 at 9:49 pm
    You can do that by placing the Effects>Normal Direction shader in the Alpha channel and then use transparency to control the opacity of the object.
    The normal direction shader simply hides the back faces of polygons (or front faces if inverted).
