Activity Forums Adobe After Effects Solid layer transparency
  • Solid layer transparency
    Posted by Micah Et on December 7, 2005 at 8:00 am
    Here are the specs… I have created a new layer whereby i created a mask using the pen tool, then used the write-on effect to draw a line along the mask.
    The problem is that i want the line to look like it is drawing onto a layer below it, but cannot seem to get the top layer (with the mask) to become transparant.
    If there is anyone out there that can solve the problem, i will label you as ‘The Man’
    Cheers,
    Mikes
    Aptjel replied 20 years, 9 months ago 3 Members · 3 Replies
  • Andrew Kramer
    December 7, 2005 at 8:23 am
    Change the paint style to “on transparent”
    Andrew
  • Micah Et
    December 7, 2005 at 8:37 am
    Not to worry,
    just as soon as i posted my query, i discovered the answer. Until next time!
  • Aptjel
    December 7, 2005 at 11:47 am
    Hi Mike,
    go to “paint stlyle” then select: on transparent or better still use stroke which can be found under render, you can control it with start or end dont forget to select a path/mask
    regards
    Apt
